Namasitar Stylophone Prototyple - new ciat-lonbarde build
MUFF WIGGLER Forum Index -> Ciat-Lonbarde
Author Namasitar Stylophone Prototyple - new ciat-lonbarde build
zilaihong
Namasitar Stylophone Prototype by Meng Qi, on Flickr
Circuit : Peter B
PCB / Design : Meng Qi
Stylophone style instrument that enables "press barre" style playing similar to sidrassi and tetrazzi.
Also with external piezo input for processing other instruments.
Guinness ftw!
julien
woah
Your new Namasitar seems to be more interesting (for me) than the two other instruments.
However i can't wait to hear them.
In fact, i seriously think to place an order for the Namasitar 8_)
zilaihong
julien wrote:
woah
Thank you.
There will be some minor change in the final version, like a small hole for easily adjusting trimmer without uninstalling faceplate.
I'll record something then, just in a few days.
Scories
Peter seems to be quite busy these days!
I'm wondering if this instrument has a similar sound to the Sidrazzi with some nearly equally tempered keyboard.
bartlebooth
actually namastitar is an old design of peter's - it has been available for a while as a paper circuit but Meng Qi recently made pcb versions of this and some of the other paper circuits which are much easier to build.
its totally different from sidrazzi and tetrazzi though.
krz
How low can she go? Frequency wise- I mean.
zilaihong
It can go VERY LOW to completely inaudible.
julien
Hi,
Any news or demos for the Namasitar/Grassi/DDDM2 ?
zilaihong
julien wrote:
Hi,
Yeah, here is the demo video for Grassi:
Still need to record the other two!
Guinness ftw!
julien
Really fast reply woah
The Grassi is a great source of noises for sure!
gde
Sorry for the necropost, but since Meng Qi released a new PCB for the namasitar I was wondering where the schematic is. I could only find a written description on the CL website
masterofstuff124
Vortex
Please could someone point me in the right direction for a BOM and build thread for the Meng Qi PCB version of the Ciat Lonbarde Namastitar?
I've looked without any joy so far
Would really appreciate some info
George
xahdrez
Hi All
Had a go at the Bom for this - mostly from the PCB, but a few bits from paper circuit. Not completely sure about diodes, or if pots should be linear/exponential. I'm not going to have a chance to order/build for a bit as too much on so please treat this is unverified, but hopefully this will help some make a bit of progress.
Namasitar Bom
Resistors
Value No. Notes
470R 6
10k 4
22k 4
47k 7
100k 1
220k 2
470k 2
4k7 7
1m 2
Capacitors
10uf 3 electrolytic
100nf 2 poly [104]
10nf 1 poly [103]
Transistors
557 13
547 9
Diodes
unknown 2 1N914?
ICS
072 2 8 pin
13700 1 16 pin
Hardware
3296W 10k 1 trimpot
50k 1 Scale [Alpha 9mm, Linear?]
50k 1 Pitch [Alpha 9mm, Exponential?]
50k 1 Mix [Alpha 9mm, Linear?]
10k 1 Volume [Alpha 9mm, Exponential]
IC Sockets 8 pin 2
IC Socket 16 pin 1
Amer1231
Necroposting this thread again, but do you guys know what the use of the "pow" and the "ladder". is the ladder a tuning trimmer?
I have a couple of these pcbs that I want to get around to build but I dont know how to properly do the connections.
