so what's it look like from behind?
ex_dead_teenager
Electro-Busker
Post by ex_dead_teenager » Fri Jun 19, 2009 3:29 am
You know I've never seen the back side of a Buchla of any vintage. I know it's not nearly as exciting as the front but I've got some questions about it's back end. For instance is it powered by a proper cable or is it a wall wart sort of thing? How many Midi dockets does it have is it midi-in only or do they also have midi-thru? And last how do the audio outputs look? Is it some kind of dual-mono type of stereo like on Evolver sequencers or are they stereo outs like you'd see on a 1/4 stereo headphone jack?
It looks like I'll be picking up a case sooner than I had expected. I heard from Don today I wrote asking if he had any in plywood and he said he had a second hand plywood case he would sell me for $300 off. I'm going to go for it because I could order it tomorrow and quite frankly while the Walnut and Zebra Wood sides are really fancy I liked the plywood cases, they're sturdy looking and tbh I think I'd be afraid to gig with something that looked as bling as some of those newer cases look. I suppose I could always trade up in the future but right now I want that case for my Pendulum Ratchet! :sb:
Anyone on here owned both the older and newer type cases and can compare them both?
Roycie Roller
Death Row Wiggler
Post by Roycie Roller » Fri Jun 19, 2009 3:53 am
Personally i find the back end of old Buchlas fascinating. It's like looking into the recesses of some alien spider's web. The circuits offer a glimpse into what it took to bring electronic synthesis to life, in a time when everything was pioneered by only a handful of people.
I haven't seen any photos of 200e innards, but here is a plethora of 200 series photos (from paults)-
Check out the MARF in particular.
http://www.synthtech.com/pix/buchla/
2012
is banned
is banned
Post by 2012 » Fri Jun 19, 2009 4:33 am
Roycie Roller wrote: I haven't seen any photos of 200e innards,
i did a search specialy for u:
ex_dead_teenager
Electro-Busker
Post by ex_dead_teenager » Fri Jun 19, 2009 4:46 am
Thank you both those are some great photos but what I'm really after is a picture of the outer rear end. That said Buchla guts are awsome. Some of those PCBs are really trippy looking.
citizen mori
Buchlidian Berk
Post by citizen mori » Fri Jun 19, 2009 4:51 am
here are some photos of a buchla cabinet. this one is a 201e wl18 cabinet.
the latches are the new style: durable and certain, rubber and steel. there are at least two other styles of latches: an elegant but ultimately tedious push-button brass latch mechanism and a less durable, slimmer plastic implementation of the current latch style.
these wood side-panels are of the thinner variety, which means that there are metal panels on the lefthand side which allow for the routing of the inter-boat connection snakes. some older cabinets have thick, thick endcaps which have no access panels.
one of the photos below is of the i/o panel for the 227e module. there are four cutouts for panels such as this and the midi i/o for the 225e. two on the upper boat, and two on the middle boat.
ex_dead_teenager
Electro-Busker
Post by ex_dead_teenager » Fri Jun 19, 2009 5:05 am
hmmn that's just what I was looking for. it looks like it's powered with a wall wart type of supply, *sigh* wall warts, as usefull as they are in the end they just sort of take over everything... not that I'm gonna complain really, with all that these instruments can do what's one more massive electrical bump on my surge protector?
citizen mori
Buchlidian Berk
Post by citizen mori » Fri Jun 19, 2009 5:11 am
it is actually a power brick style power supply. there is an iec connector on the power brick.
citizen mori
Buchlidian Berk
Post by citizen mori » Fri Jun 19, 2009 5:17 am
...here is a photo of the rear of a model 208.
ex_dead_teenager
Electro-Busker
Post by ex_dead_teenager » Fri Jun 19, 2009 5:27 am
Power Bricks are awsome I wish more things used those.
also I'll say it again those PCBs look awsome
momo
Post by momo » Fri Jun 19, 2009 6:40 am
I revisited the SOS review yesterday in full and they touch on the cabinet. I believe they really got it wrong in surmising that the plywood was an economic decision on the part of B&A. Gordon Reid is entitled to his opinion that it is cheap looking, it is however remiss to intimate that it would be any less durable than solid wood.
People who lay solid wood flooring often use plywood (not the more expensive marine grade being used by B&A) as a substrate because it is very stable. You can't stop mother nature but you can employ clever ingenuity, each leaf of wood veneer is glued 90 degrees to each other. Because wood generally moves more in one direction than the other, the effect is that any movement is cancelled out. Each leaf is glued to the other under high pressure steam and the glue is often stronger than the wood itself.
Interestingly, also in the SOS review, they suggest the 18 space boat cost $1,400 back in 2005. I'm not sure if this is a typo. Also though Don refuted many of the claims made by SOS as to the cabinet's design and durability, it appears from their FAQ page that for that reason or some other, they have revised the cabinet design in some obvious ways and apparently many others less so. I would be inclined to ascertain which era the cabinet in question is from. Or many may feel a cabinet is a cabinet is a cabinet.
Good luck and congratulations on having the option to pick one up so soon. FWIW my understanding is that Verbos' tentative turnaround is around a month so even if you had to wait for three or more for modules from B&A, you could be up and running to a degree with third party modules. The ZOe also is slated to be ready fairly imminently. Exciting times. Cheers
Roycie Roller
Death Row Wiggler
Post by Roycie Roller » Fri Jun 19, 2009 10:28 am
Cheers! He has some great photos on his page.
Lyonel
button pusher
Post by Lyonel » Fri Jun 19, 2009 11:04 am
Thanks for all those explanations citizen mori, very informative.
Boats look great and strong ...
is this the actual thickness and wood variety employed by Buchla & Associeted ?
science
Spending Spree!
Post by science » Fri Jun 19, 2009 11:21 am
You heard back from him? When?
I can't even get him to return an e-mail or call after sending him a deposit check, which was confirmed to be delivered on the 13th, and still hasn't come out of my checking account as far as I can see.
science
Spending Spree!
Post by science » Fri Jun 19, 2009 11:28 am
What really has me confused is that he responded relatively quickly to e-mails I had sent him months ago when I first started seriously considering ordering one, and over the 2 weeks before I sent my check. Ever since he sent me an e-mail telling me where to send the check, I can't get a hold of him. Guess I'll try calling again today.
550b
Post by 550b » Fri Jun 19, 2009 12:02 pm
Thanks to Roycie and Citizen for the pix. I've had trouble finding pictures of the 'boring' parts of Buchla systems (cases and guts) - most of them are of panels or spaghetti.
science wrote: I can't even get him to return an e-mail or call...
Don has always responded to my emails, eventually. Sometimes quickly, sometimes not. I try to be patient and remember that B&A is a very small company. I have never heard of anyone having trouble getting their order filled, though sometimes things are delayed a bit.
Hopefully, it just means he's busy getting systems ready to ship!
science
Spending Spree!
Post by science » Fri Jun 19, 2009 12:05 pm
I really don't agree with that. No offense to Don or anyone else, but it's not like he's receiving hundreds of phone calls and orders every day. It's not very hard to make 5 minutes to call or e-mail someone who just sent you a check for thousands of dollars... and if it is, it's time to hire help. That's just business.
cbm
Eardrill
Post by cbm » Fri Jun 19, 2009 12:50 pm
citizen mori wrote:there are at least two other styles of latches: an elegant but ultimately tedious push-button brass latch mechanism and a less durable, slimmer plastic implementation of the current latch style.
I'd like to defend the "elegant but ultimately tedious push-button brass latch." It may be tedious from a manufacturing POV, but from a user's POV it's the best latch that's been used (at least I think so.)
It has a very clean visual line, and it holds the case closed just fine.
Once again, the thinner wood w/ "access hatches" may be better from a manufacturing POV, but it is not as nice from an esthetic POV, at least for me. The combination of the thicker wood with the inter-boat wiring going through a hidden channel and the brass latches is the pinnacle of the current 200e case design, IMO.
Chris Muir
Personal -http://www.xfade.com
My Jobby -http://www.eardrill.com (Jobby = less than a job, more than a hobby)
citizen mori
Buchlidian Berk
Post by citizen mori » Fri Jun 19, 2009 2:44 pm
cbm wrote:I'd like to defend the "elegant but ultimately tedious push-button brass latch." It may be tedious from a manufacturing POV, but from a user's POV it's the best latch that's been used (at least I think so.)
your experience with these latches is very unusual, and you are very fortunate to have a rare example of reliable brass latches. i agree that they've a clean look (hence my elegancy claim) but of all the brass latch cabinets i've seen closed, only a few could be trusted to keep the system latched up.
regarding the thicker wood endcaps, i agree.
cbm
Eardrill
Post by cbm » Fri Jun 19, 2009 2:51 pm
The only "trick" to the brass latches, is to press the button while closing the case.
From what I've heard, these latches required very high accuracy in placing them in the wood, which led to a high failure rate in completed sides.
I guess I did get lucky.
Chris Muir
citizen mori
Buchlidian Berk
Post by citizen mori » Fri Jun 19, 2009 2:55 pm
Lyonel wrote: is this the actual thickness and wood variety employed by Buchla & Associeted ?
yes, currently. it may change again someday...
citizen mori
Buchlidian Berk
Post by citizen mori » Fri Jun 19, 2009 2:58 pm
cbm wrote:The only "trick" to the brass latches, is to press the button while closing the case.
lucky on latch and wood! i've more green-nose on the fortune of your wenge. gorgeous wood on that cabinet! perhaps these incidences were karmic prediction of your ratchet efforts? :love:
ex_dead_teenager
Electro-Busker
Post by ex_dead_teenager » Fri Jun 19, 2009 3:18 pm
science wrote:You heard back from him? When?
Yah Don seems sort of sketchy. When I phoned him a few weeks back he sounded rather startled and I was worried that I may have interrupted him in the millde of something but he assured me I haddn't so what ever he answered my questions and then the next day he sent me an e-mail reply addressing the questions I'd written him with.
Then I wrote him again about plywood cases and three days later I heard from him again. I couldn't tell you what's up. He seems to just do things in his own time though that's got to suck when it comes to waiting on orders. Actually I might call him today because he didn't tell me which size the cabinet was and if it's a 12panel I could put the check in the mail today though I'd be quite happy to wait two weeks for the money to buy an 18 panel.
citizen mori
Buchlidian Berk
Post by citizen mori » Fri Jun 19, 2009 3:20 pm
ex_dead_teenager wrote:Yah Don seems sort of sketchy.
d'artistes croquis souvent!! :yay:
xpander
Post by xpander » Fri Jun 19, 2009 3:57 pm
citizen mori wrote:i agree that they've a clean look (hence my elegancy claim) but of all the brass latch cabinets i've seen closed, only a few could be trusted to keep the system latched up.
i have a 201e-18 and i'm not sure what benefit the latches provide. if i transport it, it goes in the case. if i take it out of the case, it's going to travel about 3 to 5 feet to it's performance destination. maybe there's a benefit to having it latched while it's in its case? i doubt it. i'm never going to rely on the handle to carry the 200e so they seem unnecessary.
Lyonel
button pusher
Post by Lyonel » Fri Jun 19, 2009 4:06 pm
science wrote:I really don't agree with that. No offense to Don or anyone else, but it's not like he's receiving hundreds of phone calls and orders every day. It's not very hard to make 5 minutes to call or e-mail someone who just sent you a check for thousands of dollars... and if it is, it's time to hire help. That's just business.
The first and only time that i have talked to Don Buchla, i asked him why he didn't answer to my many anxious Emails about my 17000$ bank transfer ;
he told me that he wasn't very compulsive about Emails.... i think that i laughed with him. :doh:
