[Project] Random Looping Sequencer / Turing Machine
I just used what i had on hand which were actually double pole on/off/onTombola (or anyone), is there a reason for the specific switch in the BOM? Can I use just any OnOffOn SpSt switch? The one Spec'ed from Mouser is Like $7. I can save $40-$50 using what I have on hand.
momentary toggles they fitted after i cut the extra legs off [ bit of a hack ]
the holes in the board are large enough to take standard solder tag switches as opposed to pcb mount
However my panels are a custom size 241mm x 100mm so the extra width dimension of the switches i used were not an issue plus i spun the board 90 degree's in any case.
It probably wont happen today but if it does it definitely wont go smoothly.
No reason they wouldn't unless you are using one of the available panelswill 10 plain old leds work? I've got bucketloads of regular leds.
then it might look a bit naff
but of course you would be doing one of your own very nice panel designs if memory serves me right 8_)
That might work out so much better. My plan is to make an aluminum panel and drilling 10 3mm holes would be so much easier than routing out a clean square for the LED "thingy" So ya if anyone has been successful using standard 3mm (or 5mm) LEDs let us know. Maybe I'll use a few different colours for shits and giggles?sduck wrote: I bought those led array thingies, but am not particularly enamored of them - will 10 plain old leds work? I've got bucketloads of regular leds.
- Tombola
- Super Deluxe Wiggler
Ideally the write switch should be (on)off(on) - momentary ons - otherwise when you flip it up or down it will just write the whole sequence high or low.raisinbag wrote:Hey thanks Sduck, boards look great, now time to start loading them up.
But if your switches fit the board and work with your panel, they should be fine.
RE: LEDs, definitely you could use 10x (actually 9x, because one LED in the matrix isn't used) simple LEDs, you might want to tweak the current resistors.
- Tombola
Yes, my Mouser powers are weak. Thank you.sduck wrote:7$? Too much! I subbed NKK's - the (on)-off-(on) spdt one (633-M201802) was 4.46$, the on-none-on spdt (633-M201202) was 3.53$.
I've just updated the mouser BOM - cut £5 off the cost!
Full Mouser Project: http://bit.ly/MRGqRF access id: bc8a4a43bf
so "Tweaking" the resistors for single LEDs, would that be the network? I assume a standard LED might draw more Current, so would I be trying to reduce that with a larger resistor value? If memory serves the network is 330 Ohms. What should I be aiming for V OR I across each LED? I guess I can always get a 10pin Network and cut off the useless pin, as the 9 pins are hard to find locally.
- Tombola
No, there's a comparator on the pulse input. It should trigger on any voltage above 1.5v.Peake wrote: the required pulse/gate level to advance the steps. I'll assume 10V?
In practise, it clocks with every square or pulse in my little system (Dixie, Doepfer quad LFO, Maths pulse outputs, arduino pulses) and most other wave shapes, although it can be unusual with sines or E350 wavetable weirdness. There's no hysteresis (smoothing) on the clock input, so that might be the problem with weird waveforms, but it seems to work well with anything like a clock/square.
It sometimes also behaves very strangely (looped sequences disappearing) with multed/stackcabled clocks, I don't know why that is.
Yeah, I did think about that, but impatience got the better of meTombola wrote:(Although you'd find it a lot easier to paint the infill *before* peeling off the masking tape!)
Bitsy does this too, usually when the stack/ mult connection is made. I have a feeling it's the 4015 getting reset due to the short.Tombola wrote:...behaves very strangely (looped sequences disappearing) with multed/stackcabled clocks ..
- sduck
- experimental use of gravity
Depends on what kind of led you used and how bright you want it. There are green leds and GREEN ones. Most of them are fairly dull, so you'll probably be alright with the 330R. If it's too bright with the leds you have you could change the network to a 1K one or higher. If they're too dull you'd probably be better off subbing a brighter led than going for a lower network value - it's really low as it is.Navs wrote: I used a green LED. Is the 330r network still ok?
- Tombola
When I was prototyping, I had just the 330 resistor network going straight to ground. It was fine, but the current draw of the circuit seemed quite high. So I added another resistor (r19, 560 ohms) after the network. Thats why r13, which is an extra current protection resistor ( 9 x LEDs, 8x resistors in the network) is 820ohms, as close as I had to 330+560.
If you wanted your LEDs brighter, you could bridge or reduce r19, and reduce r13 accordingly, so all the LEDs are the same brightness.
But - obviously - that would cause current draw to rise.
Music Thing Modular
Radio Music Details | FAQ & Troubleshooting | Video & Audio demos | Buy
Mikrophonie | Spring Reverb | Turing Machine Expanders | Turing Machine
Music Thing Module Generator®
- Tombola
There's a link to a big png of the schematic here : http://musicthing.co.uk/modular/?page_id=21
It's not very tidy, I'm afraid
Music Thing Modular
- HueMonContact
- VoltageCtrlR
Trouble shooting time...
I just finished building a RLS and I powered it up (no magic smoke Woohoo!) and inserted a clock (NoiseRing) and the first light of the LED bar of the RLS far left blinks in unison with my Noisering but the module does not seem to be functioning properly. I can supply pictures if needed.
Thanks in advance for any help or tips.
Sound:
http://soundcloud.com/voltagectrlr
http://voltagectrlr.bandcamp.com
Game of Life Label Release: Inner Siddhi Portal
http://gameoflife.bandcamp.com/album/vo ... dhi-portal
Blog:
http://shirovoltagectrlr.tumblr.com/
http://groundloup.wordpress.com/
Video:
http://vimeo.com/voltagectrlr
______________________________________
HueMonContact...
Hue=Color, Mon=Man/Monster, Contact=Touch.
Blog:
Video:
HueMonContact...
- ultrashock
- Veteran Wiggler
- Contact:
some bump after quick styding of schematic
C6 el.capacitor (bottom left) should be reversed in polarity.
in fact, it should blow (didn't yet?
- Tombola
Well, that shows that power is coming in OK, and that the TL072 chip is working.HueMonContact wrote:Trouble shooting time...
Are you getting white noise at the noise output?
Do any of the other lights come on?
Some large photos of my boards:
