Wiard 300 system
Moderators: Kent, grantrichter, carygrace
Pascal
Wiard 300 system
Post by Pascal » Sat Jun 09, 2012 4:55 am
I cut straight to the chase, suggested system and layout of modules
Panel 01:
Classic Vco / Waveform City / Mixolator / Borg
Envelator / Sequencer / Mixolator / Wogglebug
Panel 02:
total panels 16
I want the Wiard to be used as a stand alone complete system without the need to use other format modules. I have already a monster Eurorack system and I am between a Wiard and Serge system. I am interested in the sonic and synthesis pottentials of a system and want one that is mostly analog based and quality build to last.
what do you think? any suggestions?
sandyb
Post by sandyb » Sat Jun 09, 2012 5:02 am
if you are going to be buying that much, i would suggest starting with one set of 7 modules and see how you get on first.
you may find your decision to basically have 2 of everything changes after actually using the modules for a while.
Pascal
Post by Pascal » Sat Jun 09, 2012 5:14 am
trust this has to do with the density of each panel, but do you believe I have over done it with the panels?
sandyb
Post by sandyb » Sat Jun 09, 2012 5:30 am
possibly. it's hard to say, not really knowing how you work with modulars or intend to use the modules. the 300 series modules are very dense. there's a lot going on there which takes time to discover and it certainly doesn't take 16 of them to form a very capable stand alone system.
it's a personal thing. i have 8 modules (woggle x2, classic vco, waveformcity, envelator, mixolator, sequantizer and borg) which i find is a good size system for me. i mainly use it stand alone.
what i'm really trying to say is that i don't think you should commit yourself to a 300 series setup that big until you've tried the modules first. you may have done so already of course in which case i'll shut up!
slow_riot
Post by slow_riot » Sat Jun 09, 2012 5:36 am
yeah 16 sounds overwhelming to start with.
i've picked mine up quite slowly and it's taken a long time to get to know them. You can discover stuff which makes it feel like a whole new system even after you've been using it for a long time.
I would start with 6-8 and take it from there. Add modules slowly after that when you know what you want.
With 16 modules I would just use it like any other synth and not find the treasure.
Pascal
Post by Pascal » Sat Jun 09, 2012 6:22 am
thank you both for your suggestions
sandyb: why have you decided to add a second bug at your system?
thesnow
Post by thesnow » Sat Jun 09, 2012 7:04 am
16 right off the bat sounds ridiculous. crawl before you run.
Pascal
Post by Pascal » Sat Jun 09, 2012 7:11 am
thesnow wrote:16 right off the bat sounds ridiculous. crawl before you run.
:fu:
slow_riot
Post by slow_riot » Sat Jun 09, 2012 7:14 am
heheh. Partly I'm suggesting not to get 16 straight off becuase I am jealous, but also there is a truth to it. I don't know how much you would find of the Wiard gold without starting slow.
The prices right now are the best you're going to get for a european buyer so maybe it's worth jumping in at the deep end.
fluxmonkey
Post by fluxmonkey » Sat Jun 09, 2012 8:27 am
what kind of music do you want to make?
www.fluxmonkey.com
BUILDER FOR HIRE - kits or custom, email me with your needs
sandyb
Post by sandyb » Sat Jun 09, 2012 8:36 am
Pascal wrote:thank you both for your suggestions
oh - i just like random modules a lot and the wogglebug provides so many different random voltages. i don't use it for audio that much. i like having them all doing things in a patch with their rates interlinked using the lfos. having two means i can set very different ranges for the smooth/woggle and use different amounts of clustering for them too which i find useful.
chamomileshark
Post by chamomileshark » Sat Jun 09, 2012 5:07 pm
I was wondering why you were going for 4 mixolators?
If you could get a new controller (2 joysticks + 2 JAGs) you may find that useful.
Key Gear: Wiard 300 Series, EMS VCS3, Frac Modular (Blacet, Wiard, Bananalogue & Synthesis Technology).
Pastoral Music: Mark Ellery Griffiths
Music: https://markgriffiths.bandcamp.com/
Website: https://markellerygriffithsmusic.blogspot.com/
Experimental & IDM: Mark Dalton Griffiths
Music https://markdaltongriffiths.bandcamp.com/
Website:https://markdaltongriffithsmusic.blogspot.com/
Pascal
Post by Pascal » Sat Jun 09, 2012 5:20 pm
my thought is to use mixolator 1 to mix,pan,fade audio signals and the second one to mix, pan, fade control signals
my general planning was based around a complete function block hence I used the term panel 1 and 2 which are identical.
I would like to hear your view of my planning
is the controller still in production?
HueMonContact
VoltageCtrlR
Post by HueMonContact » Sat Jun 09, 2012 5:22 pm
Paskal + Wiard 300 = eargasm
Sound:
http://soundcloud.com/voltagectrlr
http://voltagectrlr.bandcamp.com
Game of Life Label Release: Inner Siddhi Portal
http://gameoflife.bandcamp.com/album/vo ... dhi-portal
Blog:
http://shirovoltagectrlr.tumblr.com/
http://groundloup.wordpress.com/
Video:
http://vimeo.com/voltagectrlr
______________________________________
HueMonContact...
Hue=Color, Mon=Man/Monster, Contact=Touch.
weinglas
Post by weinglas » Sat Jun 09, 2012 5:26 pm
+1000
Album with Kozepz:"FRNDS"
"All Tubes"
"Game Over!"
mirarimusic wrote:... This fucking blows away Beyonces release today as well!!!!
dan_p wrote: I'll still be listening to this one in years to come. best thing I've heard for ages
Videos
Pascal
Post by Pascal » Sat Jun 09, 2012 5:27 pm
Shiro, balancing between a Wiard and Serge system I must admit Wiard has a bigger proximity effect on me. I got the blues
Pascal
Post by Pascal » Sat Jun 09, 2012 5:34 pm
thank you both, how you guys see this? any suggestions?
weinglas
Post by weinglas » Sat Jun 09, 2012 5:42 pm
Do not own a Serge or a Wiard 300, but from my point of view, sonically it is a matter of taste. The Wiard would be easier to use for me, but the bananas on the other hand are cool, too.
From an economic point of view Wiard became much more interesting for Europeans with their UK location. But you know all these things already, so i can not be of much help anyway ;)
"All Tubes"
"Game Over!"
Videos
Pascal
Post by Pascal » Sat Jun 09, 2012 5:46 pm
bananas are cool and yes moving of production to UK makes it lot easier for someone in the EU to go after it.
revmutt
Knutty For Knobs
Post by revmutt » Sat Jun 09, 2012 8:42 pm
I would suggest to start out with one panel and see what you are using the most.
I found that I use the Envelator more then the Wogglebug which surprised me. Some modules have taken longer for me to love.
Tommy DOG
Punk Rock Star, gambler and stunt double
mfirman
YuZen
Post by mfirman » Sat Jun 09, 2012 9:21 pm
I have twelve 300 Series modules and that seems to be more than enough.
I have 2 Mixolators, 2 Wave Form Cities, 2 Sequentizers, 1 Borg, 1 Filter,
2 Envelators, 1 Wooglebug, and 1 Classic VCO.
Sequencing/control may be to only short coming (the 2 Sequentizers
are great but they lack in some areas), but it depends on the music
you are trying to create. An ancillary Noise Ring (not in 300 format)
is also a good addition.
I also have a Serge system. They are two completely different animals.
Both are very, very versatile.
weinglas
Post by weinglas » Sun Jun 10, 2012 3:06 am
You could think about a combination. One panel Wiard with a creature and a WAD and an external Format jumbler. Best of both worlds. And the WAD would be a great addition to every system you have!
"All Tubes"
"Game Over!"
Videos
Pascal
Post by Pascal » Sun Jun 10, 2012 3:56 am
thank you all for your suggestions, it really helps,
revmutt: agree, besides my blue lust, this is the best thing to do, start up with one of each and then add up. I was quite happy with the organization I had come up with but nothing wrong of having some field experience before finishing the system.
mfirman: thank you for your reply, how do you compare these two since you have them both? what are the areas you think the Sequentizers lack of?
Weinglass: the Creature is something I am also considering or an Animal but this will split my resources and at the end I will have a panel here and a panel there instead of a complete system with it's pros and cons.
Pascal
Post by Pascal » Sun Jun 10, 2012 4:04 am
btw what are the dimensions and the weight of each panel?
chamomileshark
Post by chamomileshark » Sun Jun 10, 2012 4:16 am
hi, although I said 4 mixolators as they are dual mixolators it is of course 8. I only have the one in a 12 module system and though it woukld be nice to have another it doesn't really limit me. If I need a simple mixer/VCA I borrow one from my Frac modular.
But of course my set up is based on my way of working.
You would need to ask Cary about the new controller - it's quite an important block for me - for example I have 2 sequantisers, 4 oscillators but I can use the JAG to generate further sequences by routing the outputs of the Sequantizers to the X and Y inputs of the JAG.
Return to “Wiard”
