4 pin connector ?
Author 4 pin connector ?
tony d
Hi, just wondering if anyone can tell me if these are the correct female connectors for the 4 pin power cables used w/ "motm" style boards.
Thanks.
http://www.mouser.com/Search/ProductDetail.aspx?qs=sGAEpiMZZMvlX3nhDDO 4APK9C%252bElCF6cNLld%252bjcskZw%3d
ndkent
I think you want the "with locking ramp without polarizing" type
571-3-640426-4 ?
http://www.mouser.com/catalog/catalogUSD/638/1394.pdf
The one you linked to looks like it would fall out without the locking ramp
tony d
Perfect! Thanks
scozbor
does anyone know where to get the right-angle types?
also the 'through connectors' (ie. power cable continues past first header and into another)?
For the rght angle ones you must mean the headers? something like these?
http://www.mouser.com/Search/Refine.aspx?N=3748020+4294635164+42946351 63&Keyword=MTA+156+header+right&FS=True
For 'through connectors' see the ones called FEED-THRU on the same page Nicholas provided above.
scozbor
these are the ones i am after. and now that I look at them they look to be a feed through type female connectors...
scozbor, note that the caps are different too so make sure to order the right ones. spinning
sduck
Since you showed the picture of a doomsday machine, which I happen to have a BOM for here, here's what's listed in that BOM for these parts -
for the main power connections, (red in your picture)
Mouser #571-6404264 (connector)
Mouser #571-6405514 (dust cover)
for the feed through one - the one in the middle of the cable - (yellow in your picture)
Mouser #571-6405994 (connector)
Mouser #571-6406434 (dust cover)
I use these, they work.
