DMM = DVM?
haricots
Droppin' Loads
DMM = DVM?
Post by haricots » Thu Jul 09, 2009 3:46 pm
I'm having a fark of a time tuning my Pro One by ear. I have a DMM, but can this somehow be used to measure volts by making leads that can plug directly into the 1/4 output?
ElectricPuppy
Post by ElectricPuppy » Thu Jul 09, 2009 3:56 pm
Yeah, you could but what's the 1/4 outputting? Audio? You won't get a meaningful "voltage" reading from that. If you're tuning and you want hard figures, what you want is a frequency counter.
Unless I misunderstand what you're asking...? :despair:
Luka
Post by Luka » Thu Jul 09, 2009 4:22 pm
you would need a frequency counter
best thing to do with tuning is to get a reference source like a synth in ableton or some other synth you have
make sure the filter is open so you have a full osc waveform
then start at c1 and press that along with the c1 on your reference
you will hear when they are close are they will start phasing
and when they sync you will notice a nice harmony
sometimes if im a bit lost i will keep the reference not playing and then hit around the 1st octave on your out of tune keys so see which note is closest
this will give you an idea how out of tune it is
then once you nailed that move up the octaves till you get as high as it will go
then it is tunes !
not all that easy
first time i did it it drove me mad but you get the hang of it
wetterberg
Post by wetterberg » Thu Jul 09, 2009 6:59 pm
FYI a lot of people HATE using frequency counters, and simply use inexpensive guitar tuners instead.
haricots
Droppin' Loads
Post by haricots » Thu Jul 09, 2009 9:02 pm
ElectricPuppy wrote:Yeah, you could but what's the 1/4 outputting? Audio? You won't get a meaningful "voltage" reading from that. If you're tuning and you want hard figures, what you want is a frequency counter.
Sorry, I meant the cv out, not audio out. Brain fart.
haricots
Droppin' Loads
Post by haricots » Thu Jul 09, 2009 9:06 pm
Luka wrote:then start at c1 and press that along with the c1 on your reference
then it is tunes !
Thanks Luka. The issue I'm finding is with all the offsets, scales, hi trim, -1v trim variables > http://www.flatline.net/Projects/Audio/ ... Fig51L.gif
I'm following the instructions (http://www.flatline.net/Projects/Audio/ ... Section5-3) but I'm just not getting there ....
haricots
Droppin' Loads
Post by haricots » Thu Jul 09, 2009 9:17 pm
Never mind, I figured it out. Tuned much better now after trimming like mad. :)
