Patching Up A Compressor
Moderators: Kent, lisa, luketeaford, Joe.
Post by Babaluma » Thu Jul 09, 2009 9:07 pm
I realised most of my info on this was posted over on modularsynth.net, but it would be cool to have it discussed here also.
I was playing with the patch again the other day, and achieved some stellar results. It sounds better than my Chandler Germs Comps on some things, and is especially good at that "thwippy/thwappy" sound I associate with an 1176.
Relevant info and sound files available here:
Luka
Post by Luka » Thu Jul 09, 2009 10:54 pm
if it is just gating when the evelope is hit with larger peaks isnt that limiting not compression?
i would think adding an amp at the end of your chain would allow you to amplify the floor and still squash the peaks
consumed
International Filter Conspiracy
Post by consumed » Fri Jul 10, 2009 12:31 am
thanks for putting that back up, its a fantastic patch! i was just thinking on this a day or so ago
its more of an effect instead of the typical squashing of some comp/limiters
you're following the amplitude of an incoming signal,
but inverting it. so that the filter freq is pulled DOWN as the amplitude is higher
Post by Babaluma » Fri Jul 10, 2009 4:03 am
Luka wrote:if it is just gating when the evelope is hit with larger peaks isnt that limiting not compression?
it's not just gating on/off, the amount the gain reduction element (e.g. a VCA, or here, a borg2 filter acting as a low pass gate) reduces the gain is directly proportional (and inverted) to the input level.
remember there is no "envelope" module in this patch, only an envelope follower (the VCS patched as such).
as for limiting versus compression, they are both the same. a limiter is just a compressor with a very high ratio. in my patch you can't really control the ratio. you can alter the threshold by how hard you drive the patch. this "thresholdless" type can be found in an 1176 or chandler germ comp.
this patch does tend to darken things up a bit, i am sure it would be different/cleaner if you substituted a VCA for the low pass gate. try it and see! it does also pull down the volume somewhat, but like you say, that is what make up gain is for, and i can do that within the modular itself, or with an external pre.
Post by Babaluma » Fri Jul 10, 2009 4:08 am
consumed wrote:thanks for putting that back up, its a fantastic patch! i was just thinking on this a day or so ago
thanks dude!
if you listen to my sound files or patch it up yourself, you can hear some gorgeous sweet spots, especially on percussive material. i'd been looking for that uber-pillowy ringo "for the benefit of mr. kite" kick drum sound for ages, couldn't achieve it with my chandlers, but it's easy to get with this patch.
you're right it's much more of an effect comp sound, very obvious, i wouldn't really want to use it for transparent compression, but transparent compression is boring unless you are a mastering engineer!
again, trying to get it to work with a clean, low noise VCA might be better for more transparent work.
Post by Babaluma » Fri Jul 10, 2009 4:15 am
of course the real beauty with this patch is the tweakability you have over the attack and decay times via the VCS. they are both individually voltage controllable and you can choose linear, log or exponential slopes (or anywhere in between) independently for the attack and release. find me an off the shelf compressor that can do that!
for finer control set the rise and fall in the correct ballpark, and run a steady 5-10V signal through an attenuator or two. this will give you extremely fine control over the attack or release times, which is exactly what you need when tweaking it to the tempo of the track etc.
i think the other thing that turns this into such a star patch is the way the borg2 responds to the CV from the VCS. the built in decay of the vactrols just adds something truly wonderful.
rico loverde
Post by rico loverde » Fri Nov 26, 2010 11:30 pm
awesome post!!!!!!!!!
works for Darkplace Manufacturing
Post by Babaluma » Sat Nov 27, 2010 3:38 am
zombie thread!
:lol:
yeah, probably my favourite patch of all time!
tony d
Post by tony d » Sat Nov 27, 2010 5:47 pm
Mine also.I have plans to build a standalone box specifically inspired by this patch.
Post by Babaluma » Sat Nov 27, 2010 11:15 pm
Yep, sounds cool. Would be pretty easy to create a stereo linked version too. Like a Mutator on steroids!
Brownian Lotion
Continuous random talk
Post by Brownian Lotion » Sat Dec 04, 2010 10:43 am
Found this thread via search and interlinked posts. This forum kicks ass.
Reckon i can patch this with a vca, a106-5 abd a maths... Can anyone recommend a good envelope follower or should i stick with the maths?
chinard
Post by chinard » Sat Dec 04, 2010 11:22 am
well the maths should be able to do the job of envelope follower and inversion all in one place.
Just curious about why a borg filter was specified here.
any advantages over a regular vca?
tIB
Stainer!
Post by tIB » Sat Dec 04, 2010 11:34 am
^ it does, I did this the other day with maths and qmmg.
EDIT: Oh and patching the negative slopes into channels 2 and 3 of the maths, inverting them so they are positive and then patching them to the qmmg's feedback control input was giving interesting results.
confusional
Post by confusional » Sat Dec 04, 2010 1:32 pm
Redacted.
wintermute
Post by wintermute » Mon Jan 31, 2011 7:34 pm
Have you thought about applying that patch to parallel compression?
Eg. Taking that 606, running it through a desk, and using an aux output as the input for the modular.
The benefits of parallel compression shouldn't be overlooked. Whenever you thought "I wonder how they got that punchy drum sound" it's often been through parallel compression.
Post by Babaluma » Tue Feb 01, 2011 4:09 am
yeah, i've thought about it, but i usually use my chandler germ comps for parallel compression. if i was going to do it in the modular, i'd just stick a mixer after the patch and feed it the output of the comp patch plus the original input sound source. the you could mix and match to taste within the modular itself (no need for an external mixer).
you're right though, parallel/new york compression can sound really great on drums. don't normally like it on a whole mix though.
...i need to get a stereo linked version of this patch up and running...
(mult the L and R signals. feed one to a mixer balanced 50/50, use that combined signal to feed the envelope detector. feed the other multed L and R signal through two identical VCAs/LPGs but get the CV inputs of both fed by the combined signal).
wintermute
Post by wintermute » Mon Feb 07, 2011 2:05 pm
Babaluma wrote:don't normally like it on a whole mix though.
It's great for mastering, as you can place any sort of limiter you want after the chain, so neither are working too hard. It will increase the noisefloor, but careful selection of which audiobands to compress can help.
Wouldn't you want the mixer panned hard for a stereo version?
Post by Babaluma » Mon Feb 07, 2011 5:25 pm
I've mastered about an album a month (plus loads of single tracks) over the last year, and have used parallel compression on maybe 5% of them or less. I often find it does weird things to the mix levels and stereo width, and way more often find I prefer "regular" compression on the whole mix. I like to use parallel compression more on things like the drum buss, where you can really really mash it and then bring a little of the dry sound back in to add life/dynamics again.
Yep, for that compressor patch in stereo you'd definitely want the two final outputs going into two separate audio channels (either on an external mixer or directly into a d.i. or interface), otherwise it wouldn't be stereo!
M78
Post by M78 » Mon May 23, 2011 12:21 am
i know it's been mentioned before but i would love to know how to get this to work with maths + other modules...has anyone tried that?
Post by Babaluma » Mon May 23, 2011 3:09 am
theoretically it should work with any env follower + vca(or lpg), but it can be a very "tweaky" patch to get just right.
not tried it with a maths, but when i used the envelope follower on the blacet I/O module, and a regular blacet vca, i got less than stellar results, but again, i just may not have spent enough time hunting down the minuscule sweet spot.
cillianjohn
Post by cillianjohn » Sat May 28, 2011 9:39 am
I got side chaining to work with my maths today.
Bass drum sound (lfo to gate) coming from the Dark Energy which is the signal to be followed. This signal is fed into channel 3 to provide some gain. Ch.3 out to channel 4. Set rise to 12 o'clock. Tweak fall for varying responses. Then take the Or output to your VCA of Filter cutoff. (In my case both as I was using an LPG). The audio it is side chaining is a sine drone from my ulfo.
Babaluma wasn't kidding about the tweakiness of this patch.
Ps. How to patch maths as an envelope follower is described excellently in the maths manual which I used to help me with this patch.
cillianjohn
Post by cillianjohn » Sat May 28, 2011 9:41 am
^^Sorry about the shaky phone-cam.
JJ
Post by JJ » Fri Oct 28, 2011 6:21 pm
Awesome thread, anymore cool findings since the last post?
numan7
the most autistic amongst us
Post by numan7 » Sat Oct 29, 2011 6:15 pm
thanks for reminding me bout bab's aweseome notes! :hail:
here is my desktop (until this patch is so burned-in that i don't need any reminder :hihi: ) !
once again, thanks :) !
cheers,
7n7
"the ordinary will ignore whatever they cannot explain as if nothing ever happened. and everything remains the same again..."
Post by Babaluma » Sun Oct 30, 2011 9:56 am
that rules! ;)
:lol: :lol: :lol:
