it works 828 and system 100m
Discussion and support for MOTU's Volta software.
Moderators: Kent, stretta
markus enochson
Post by markus enochson » Thu Jul 16, 2009 11:05 am
just letting you guys know that i successfully calibrated roland system 100m oscillators with a 828 so it can be added to that approved list
and there were much rejoice
m
as precaution i did is with the 828 and my mac book pro now i'm gonna integrate it to my much more convoluted setup with my imac involving profire lightbridge and my metric halo... fingers crossed
dougt
Post by dougt » Fri Jul 17, 2009 12:20 am
The original mkI 828? I thought it couldn't put out enough voltage...
markus enochson
Post by markus enochson » Fri Jul 17, 2009 2:53 am
the original 828, had it laying around since a live tour back in the days.
i managed to get quite a good range out of the 112 osc
m
markus enochson
FYI but only if you use it as main interface
Post by markus enochson » Fri Jul 17, 2009 1:08 pm
it seems impossible to get the 828 to work after a adat interface (pro fire lightbridge) cause there is no routing program or stand alone mode on it...
i tried to do an aggregate device and i could create it but it would not (play) clock nice with either metric halo or pro fire lightbridge as master...
so i will run the 828 from my laptop in sync with my main rig until i decide i get a new motu interface or a volta expander sort of product jumps along
m
:bang:
1nput0utput
Re: FYI but only if you use it as main interface
Post by 1nput0utput » Fri Jul 17, 2009 2:18 pm
markus enochson wrote:it seems impossible to get the 828 to work after a adat interface (pro fire lightbridge) cause there is no routing program or stand alone mode on it...
m
:bang:
The 828 should work well in an aggregate device. What if you make the 828 the master clock device instead of the other interface?
markus enochson
Post by markus enochson » Fri Jul 17, 2009 3:50 pm
i did try that too, i think it has something to do that i'm daisy chaining it of the metric halo fw port.
i run everything on an imac so my last chance 2morrow will be to try an adapter 800/400 fw or cable as such. even though its the same fw bus it might change things up, at least worth 20 bucks to try it out
if i were to buy a new motu today i guess a 828 mk 2 would suffice right? since it has stand alone mode? would be very interesting to see that rumoured expander but thats gonna be a while before that comes round
m
dougt
Post by dougt » Sat Jul 18, 2009 10:19 pm
markus enochson wrote:the original 828, had it laying around since a live tour back in the days.
m
How many octaves can you get out of it?
markus enochson
Post by markus enochson » Thu Jul 23, 2009 5:48 am
it calibrates 4 oct. will change interface to a mk2 cause i want to use it as standalone via adat
m
Return to “Volta”
