balanced outputs from Mixolator
Moderators: Kent, grantrichter, carygrace
slow_riot
Post by slow_riot » Tue Aug 21, 2012 11:03 am
from Grant:
A balanced output, has both the positive and negative version of a signal on a single 3 place connector. You can use either an XLR or TRS jack for this. Just take two 3.5 mm patch cables, cut one end off, connect the shields together to the sleeve, connect one hot to the tip, the other hot to the ring. Close it all up, and when you plug the two remaining 3.5 mm into the plus and minus Mixolators outputs , the TRS jack is now a balanced send.
You should be able to buy all parts at a Radio Shack store anywhere in the world.
Your Welcome.
sabasan
Post by sabasan » Wed Aug 22, 2012 4:30 am
:hmm:
Return to “Wiard”
