quandary solved. thanks.
Moderators: Kent, grantrichter, carygrace
thesnow
Post by thesnow » Thu Aug 23, 2012 8:38 pm
screws loose = tightened. quandary solved.
sandyb
Post by sandyb » Fri Aug 24, 2012 1:35 am
remove the metal casing, see where the offending item came from, put it back.
things sometimes become loose in shipping. i very much doubt it will have affected the operation of the module although obviously test it to make sure.
thesnow
Post by thesnow » Fri Aug 24, 2012 3:02 am
sandyb wrote:remove the metal casing, see where the offending item came from, put it back.
thanks, sandyb.
sandyb
Post by sandyb » Fri Aug 24, 2012 3:25 am
thesnow wrote:... I'll prob edit this thread slightly like a "quandary solved" thing once things are cleared just to clear any unnecessary wiard thread that sounds sketchy. but thanks for your comment. I'll wait to hear from cary then go from there before actually opening up anything first.
to be honest it would imo have been best to wait to hear from cary before posting about it on the forum for that very reason.
as for opening it up - you're not going to do any harm. it's a handful of screws and the casing just comes off. you could have this sorted out before cary even gets back to you! think of it as practice. if you continue down the modular path you'll have to get used to doing the odd bit of simple maintenance. sometimes nuts holding knobs/jacks in place need tightening or cables need reseating.
thesnow
Post by thesnow » Fri Aug 24, 2012 3:31 am
op updated. quandary solved. thanks a lot for your help!
Return to “Wiard”
