Explain the Buchla 256e Please...
drewskee
Post by drewskee » Mon Jul 27, 2009 3:37 pm
Ok, so I am no newbie having a two panel custom Serge and a panel of Buchla 200e with the 261 / 281 / 292 / 266...which can do lots of stuff.
I am thinking about a second 200e panel with an additional 261, 206, 256 and possibly a Morph Filter (now that I would have presets via the 206) or the Freq Shifter.
I have read here and there that the 256 does not really do "mixing" or cross fading and I am trying to get the TRUTH on whether you can fully crossfade between CV 1 and CV 2 inputs and/or get equal mix in the center?
If not, can someone splain' how is DOES work so I have some idea of it will do what I'd like...which is to make all sorts of weird composite mod sources using 266 + 218 + second slot of 256 etc, etc.
:help: :dizzy:
prscrptn
Post by prscrptn » Mon Jul 27, 2009 3:53 pm
The 256e is very useful for creating complex control voltages; (see the link below).
http://xfade.com/Buchla/256/
Thanks Chris! :tu:
drewskee
Post by drewskee » Mon Jul 27, 2009 4:56 pm
Right....thanks! Been there, read that but also have noticed others saying that the mixing/cross fading does not perform as expected...either it does not cancel out fully when at one extreme or the other...or....the mixed voltage of the two inputs did something weird/unexpected (excluding the transfer function etc).
Wish i could articulate better, cannot find the old posts from Yahoo Group etc.
Thanks again!
cbm
Eardrill
Post by cbm » Tue Jul 28, 2009 3:17 am
Like most audio crossfaders, the 256e has some sort of fade law. I don't know exactly what it is, but when the select knob is in the 12:00 position, both the input channels are attenuated a little bit, so that the total output doesn't clip. This is what you want for a CV crossfader, IMO, but might not be what you want for a CV mixer.
In practice it hardly ever bothers me that I can't have two sources mix at 100%.
Chris Muir
Personal -http://www.xfade.com
My Jobby -http://www.eardrill.com (Jobby = less than a job, more than a hobby)
cbm
Eardrill
Post by cbm » Tue Jul 28, 2009 3:40 am
To elaborate just a bit further, yes you can get either input source, or a crossfade of the two of them. They are equal in the middle.
Chris Muir
xpander
Post by xpander » Tue Jul 28, 2009 2:18 pm
if you only have one input, does the crossfade knob scale the signal? i'm picking mine up tomorrow so i've been really trying to figure out exactly how it works before i even toy around with it.
cbm
Eardrill
Post by cbm » Tue Jul 28, 2009 2:40 pm
Yes. If you put your signal into in 2 (e.g. LFO from cycling section of 281) and your control source into select (e.g. MIDI Mod wheel from control bus from 225e), the 256e will scale your LFO from 0 to full with Mod wheel travel.
Chris Muir
xpander
Post by xpander » Tue Jul 28, 2009 5:22 pm
excellent- i'm looking forward to much, much more functionality in my system tomorrow.
drewskee
Post by drewskee » Mon Aug 17, 2009 4:36 pm
cbm wrote:Like most audio crossfaders, the 256e has some sort of fade law. I don't know exactly what it is, but when the select knob is in the 12:00 position, both the input channels are attenuated a little bit, so that the total output doesn't clip. This is what you want for a CV crossfader, IMO, but might not be what you want for a CV mixer.
Yeah, that would not be a problem for me either since it is all for creating psychotic cv's anyway...no tonal sounds for me!
