Dual Complex VCO with Video - Audio - Pics
MUFF WIGGLER Forum Index -> Music Tech DIY Goto page 1, 2, 3 ... 23, 24, 25  Next [all]
Author Dual Complex VCO with Video - Audio - Pics
J3RK
Please see Page 23 for attached documentation. The files hosted below were removed by the ISP.
Also, there is a ZIP with all of my project docs here:
https://www.muffwiggler.com/forum/viewtopic.php?t=150552&highlight=
Old Information / Original Post:
The docs are up, and now updated with wiring diagrams, pics, more notes, updated notes, etc.
New MCVCO Schematic:
http://home.comcast.net/~r3cogniz3r/mcvco-schematic.pdf
Docs Updated 11/11/2013
http://home.comcast.net/~r3cogniz3r/MCVCO-Docs-Updated-11-11-13.zip
Lorlin Hex Rotary Datasheet: http://www.lorlin.co.uk/PDF/BCK.pdf
Please post questions in this thread. I'm quite happy to help!
Old First Post:
Hello!
Thought it was about time to mention what I've been up to for a while (aside from boxed-synth building.)
Since Complex Dual VCOs seem to be the thing to build these days, here's my take:
This will be a three board setup. 2 identical VCO boards, and a control board. The boards are 5"x4" so are Euro friendly on one axis. (this will require a lot of panel space anyway for all of the controls and connections, so these dimensions should be fine in all cases.)
The VCOs I'm calling "Mirror Core". It's our take on the internals of a CD4046 VCO, only built out using separate components. The CD4046 VCO didn't have high linearity for tracking in mind, so we've improved this significantly. I call it Mirror Core because it uses two opposing sawtooth cores (more or less) which is able to generate a perfect 50% square wave.
One of the more unique features is that we expose a logic level unipolar output, which can be used for clocking and logic purposes.
Features of the VCO:
Coarse/Fine tune controls.
1V/Oct input (high tracking range)
Linear FM input
PWM control
PWM CV input
VCO/LFO switch
Saw wave out
Tri wave out
Sqr 50% wave out
PWM wave out
Logic pulse out
Sine wave out
VCA in
VCA out
VCA CV in
Lockhart folder in
Lockhart folder out
Control Board Features:
XOR A in + LED
XOR B in + LED
XOR out + LED
Dual Edge Divide by N and Divide by N.5 in
Dual Edge Divide by N and Divide by N.5 out
Dual Edge Divider 16 position rotary
Dual Edge Divider Edge Select switch
Dividided signal LED
LED driver 1 for VCO 1 Logic Pulse Out
LED driver 2 for VCO 2 Logic Pulse Out
Integrator in
Integrator out
Integrator Range control
All features can be brought to the panel however anyone sees fit. I personally will bring them all out as patch points, so I can use each component externally as well.
Between the 2 VCOs and the XOR (or external logic,) complex rhythmic patterns can be made.
The VCAs on the VCO boards are the Mike Sims dual OTA design for low noise/distortion. The wave-folder is a simple Lockhart folder ala Ken Stone's simple folder. Since there is one VCA per VCO, one can be used for an FM index VCA, and the other can be used as a CV input for the folder, (or anything really.)
As you may have noticed, the boards contain everything one needs to do Phase Locking. Just take the logic level signals, patch to the XOR, integrate, divide, and lock the second VCO. You could of course wire this all up, and have a switch that says Lock on it, but I think the XOR and Divide by N are quite useful outside of this function. (so I wouldn't do it that way.)
I've ordered prototypes for the VCO board, and have just finished the layout for the control board. (I'll be ordering protos for that in about a week.) I've been speaking with Clarke about the possibility of a panel for this as well. Once I've tested the full three-board configuration, I will be able to give him more solid IO/control specs after I'm sure everything's good as is.
Anyway, I'm hoping to make these available very soon. I just have one other major project to wrap up for someone first.
Update
All audio demos are now in my Soundcloud page under the 5U set. All of the sounds there are using this VCO.
http://soundcloud.com/drj3rk/sets/stroh-modular-5u
thebot
WANT! Seriously, that sounds great.
HueMonContact
This sounds really awesome. I love the amount of functions you packed into the design. Great job!
pre55ure
Sounds awesome, I'd definitely be in for one (assuming it's not ridiculously expensive).
Extra awesomeness if Clarke does a panel as well. Rockin' Banana!
sduck
I'll definitely order 2 sets!
Dogue
Intrigued over here, I says.
hexinverter
Looks fun grin
Are there any vactrols? hyper
decaying.sine
2 board sets for me too.
This smells like a 4U wide MOTM panel with the traditional grid spacing. Not bad for all the features, really.
djangosfire
Sounds excellent! I'm in for a few for sure w00t
nickster
Marvellous news ! nanners It's peanut butter jelly time! Rockin' Banana! (all the positive bananas for you sir)
I am very interested in building this project so count me in, please.
Rod Serling Fan Club
Nice, what does the "integrator" do?
tony d
Awesome ! I think i've found my next project.
lordofthebored
Color me this sounds really cool!
andrewF
J3RK wrote:
The VCOs I'm calling "Mirror Core". It's our take on the internals of a CD4046 VCO, only built out using separate components. The CD4046 VCO didn't have high linearity for tracking in mind, so we've improved this significantly. I call it Mirror Core because it uses two opposing sawtooth cores, which is able to generate a perfect 50% square wave.
Great idea! Good luck with the project
synthcube
Awesome! Count me in.
raisinbag
help applause
hexinverter
Can't wait to see/hear a demo of this one. Nice work sir screaming goo yo
whitewulfe
Loving the sound of where this is going!
blinosynth
also a rod serling fan club pannel would be great! a buchla-euro pannel (or just a buchla pannel for who would build buchla)...
Luka
sounds interesting jerk
looking forward to a demo
Kalerne
nodnod
theabsent
Interesting
ringstone
Sounds very interesting... I'll be on board for at least 2!
Blair
johnnly
Looking forward to hearing more.
mOBiTh
8_)
Page 1 of 25
