Xoxbox CV to filter cutoff solved!
Author Xoxbox CV to filter cutoff solved!
acidbob
Hi,
I am planning on fitting a CV in for the filter cutoff on my xoxbox, has anyone done this, I could use a little guidance.
Sniper¨¨¨¨¨¨¨ ¨*Cheers
Microscopial
Me too
acidbob
So here we go, don't mind the ugly soldering, it's just for test.
Correction: Use ~250-300K resistor, this way you can bias the filter on the xoxbox, and be able to do a more fine adjustment, and you will be able to go lower on the cutoff.
By the way, use a normally closed jack!
Detonacid
Hello is that this mods for the xoxbox actually works.
Thank you in advance and good day
smile
Detonacid
I do not see any CV protection. as explained here. What do you think?
http://www.ladyada.net/wiki/x0x/cvprotection
Thank you
