Video
chrisso
Video
Post by chrisso » Thu Aug 20, 2009 5:21 pm
Those of you who post modular demos on YouTube and the like......
What video camera do you use, and more importantly, if you record the sounds to a DAW or HD system, how do you sync the pictures to the sound (as it's obviously not recorded to the camera's audio)?
Thanks for any advice.
Post by Babaluma » Thu Aug 20, 2009 6:13 pm
i use a panasonic SD-100 which is HD and has dolby 5.1 channel surround mics. youtube audio and video qaulity is pretty poor after the conversion, so i don't see anything wrong with using the cameras built in mic.
chrisso
Post by chrisso » Thu Aug 20, 2009 7:14 pm
Possibly, except many synth demos are spoilt by room acoustics and similar.
The best video demos, where you can really hear the synth, seem to be direct recorded from the synth itself, rather than with mics.
bf
Buck Futter
Post by bf » Thu Aug 20, 2009 7:20 pm
Post by Babaluma » Thu Aug 20, 2009 10:12 pm
well i guess if your camera has a line in you can just feed it from your mixer while you are shooting?
Post by Kent » Fri Aug 21, 2009 1:56 am
I am using a Kodak Zi6. It's major downside is that it does not have a line in. Thus, I record into my DAW at the same time and then line up the camera's mic-audio with the DAW audio by hand in iMovie.
I agree that the room acoustics in a lot of YouTube video are less than ideal which is why I go through the considerable hassle that I do.
HexEnduction
Post by HexEnduction » Fri Aug 21, 2009 2:21 am
Kent wrote:I am using a Kodak Zi6. It's major downside is that it does not have a line in. Thus, I record into my DAW at the same time and then line up the camera's mic-audio with the DAW audio by hand in iMovie.
Kodak just updated the Zi line of cameras, actually. The new Kodak Zi8 has a line in now and it shoots 1080p.
I've been using the Zi6 as well and I'm guilty of being one of the aforementioned lazybones that uses the mic in so the sound is usually less than desirable. Today I shot a video and used Logic for recording the audio and combined the two together in a similar way to what Kent described above. It was a pain in the ass and the compression on YouTube is nothing to write home about after all the hassle. :doh:
I think the best solution will be to give the Zi6 to my brother and just grab one of these new Zi8 cameras. Laziness prevails!
chrisso
Post by chrisso » Fri Aug 21, 2009 7:07 am
Babaluma wrote:well i guess if your camera has a line in you can just feed it from your mixer while you are shooting?
Ahh, of course.
Good idea.
