Snarky Tuner ($12 Tuner Mod for Modular)
- pulplogic
- Wiggling with Experience
- Contact:
The Snark SN-2 makes a descent little tuner for modular. It costs around $12 on ebay and the mods for adding a 3.5mm phone connection is fairly easy to do. I simply removed the internal piezo sensor and connected directly to its connections.
- pulplogic
- Contact:
Thanks, here are a couple of assembly pictures:aladan wrote:That's way cool... couldn't stop myself, just bought one!
Cut the tabs down so they don't contact the piezo sensor and solder the ground and signal wires.
The flex tube was scavenged from a broken usb led lamp. Hot glue secures it into the socket.
- joshuagoran
I used the original arm with a ball joint on each end. I removed the ball from one end so it fit into an 1/8" jack. Then used heat shink to keep those two parts together. The wires had to enter the 1/8" jack through a hole I drilled in the side. Finicky build but it works well with minimal parts. The pitch tracking on the latest model seems very stable.
- craigwilliamsmusic
- Common Wiggler
I panelised an SN-8 version
a couple of months back
added a 3.3v regulator so no battery any more
brought all the switches out to the panel and added an in and buffered through jack
really useful module
also bought a couple of even cheaper ENO music ET-33
tuners , i plan to do the same with them.
It probably wont happen today but if it does it definitely wont go smoothly.
- joshuagoran
- squarewavesurfer
- mothertongue
- Common Wiggler
- sduck
- experimental use of gravity
Ok, this was a lot easier than I thought it was going to be. First, I scoured the whole house, trying to find some kind of flexi tube I could use, cause that looks really cool. After spending way too much time doing that, I realized I was probably just overthinking things, and that I could just use the clip that comes with it, attach it to a jack of a clipped off patch cord. So I picked out a suitably colored Hosa patch cord and got busy (purple works best!
Opened it up, removed the piezo, drilled a hole, stripped the wires, soldered them on, put little bits of electrical tape over the business side to prevent accidental contacts on reassembly, re-attached the little button pieces, reassembled the whole thing, it works great!
The super snark has a little spring thing for the ground contact, otherwise the connections are the same as in the pictures and videos above.
This method might not work so well with euro size patch cords, but with 1/4" ones it's fine.
- squarewavesurfer
I should have mentioned that my SN-2 (pictured above) also had a spring for the ground contact. This is probably just the way they are making these tuners now.sduck wrote:The super snark has a little spring thing for the ground contact, otherwise the connections are the same as in the pictures and videos above.
- hangovercat
- domestic party animal
That's going to be super handy. Thanks a ton.
"An idea isn't responsible for the people who believe in it." – Don Marquis
ModularGrid
BandCamp
SoundCloud
ModularGrid
BandCamp
SoundCloud
