Here is our take on a "West Coast" voice using only Intellijel modules:
The Rubicon is the primary VCO with TZFM
A Dixie II is the modulator
Dixie square acts as sync source for Rubicon
Rubicon Saw acts as reversing sync source for Dixie
(two way sync patch)
The Double Saw out and Pulse from the Rubicon are fed to the two inputs of the Korgasmatron II. Using the xfade on the Korgo you get an ODD/EVEN control. Put both filters into HP to get a high harmonic output.
Feed Mix out of Korgo II to Azimuth (put in Xfade mode) and a Sine from the Rubicon to the other input. Now xfade those and the result from the L Out is a blend of LOW/HIGH (called "Order" on the Buchla 261e).
Feed output of the Azimuth II to input of the uFold II for Wavefolding.
A second Dixie is present as an extra assignable modulation source.
You can get AM by patching an FM source into the VCA inputs of the Azimuth II (should be multed to modulate both at same time).
FM Depth VCA (index) is built into the Rubicon. You can patch back to Dixie to modulate the source. You can use a Triatt as an attenuator for this two way modulation and as a morph control voltage source.
With this as a basis you can start tweaking parameter, re-patching and adding more modulation sources like a Quadra for envelopes or a Planar to morph between up to 4 sources (or route audio/cv to 4 destinations)
Deluxe version:
