E.A.S. MINDREADER BUILD THREAD
MUFF WIGGLER Forum Index -> Music Tech DIY Goto page 1, 2, 3, 4  Next [all]
Author E.A.S. MINDREADER BUILD THREAD
E.A.S.
Here is the build thread! As time passes this post will slowly get edited with the most up to date info.
Have a question? check here first!
Thanks!!!
-Mike
Schematic A : Main Circuit
MS20 ESP PAGE 1 by itsfatmike, on Flickr
Schematic B : Log amp
MS20 ESP PAGE 2 by itsfatmike, on Flickr
Parts Placement :
mindreader parts placement by itsfatmike, on Flickr
NEW Wiring Diagram :
NEW-ESP wiring diagram by itsfatmike, on Flickr
B.O.M. :
C1 1uF
C2 12000p
C3 220p
C4 220p
C5 .015
C6 .056
C7 .015
C8 .015
C9 .015
C10 .033
C11 .056
C12 .033
C15 1uF
C16 1uF
C17 100p
C20 100p
C21 100p
D1 1N4148
D2 1N4148
D3 1N4148
D4 1N4148
D5 1N4148
IC2 LM339
IC3 TL071
IC4 CD4069
U2 TL074
U3 TL074
U4 TL072
LED1
LED2
Q1 2N3904
Q2 2N3904
TR2 2N3904
TR5 2N3904
R 10K
R1 820R
R2 100K
R3 22K
R4 100K
R5 100K
R6 150K
R7 2.7K
R8 4.7K
R9 4.3K
R10 10K
R11 2.7K
R12 47K
R13 22K
R14 47K
R15 22K
R16 220K
R17 2.2M
R18 1K TEMPCO, pads for either thru-hole or SMT
R19 100K
R20 680R
R21 3.3K
R22 4.7K
R23 22K
R24 100K
R25 100K
R26 15K
R27 10K
R28 10K
R29 220K
R30 1K
R31 10K
R32 4.7K
R33 10K
R34 2.7K
R35 2.7K
R36 470R
R37 10K
R38 1K
R39 10K
R40 2.7K
R41 2K
R42 2K
R43 2K
R44 2K
R45 2K
R46 2.7K
R47 22K
R48 1K
R49 220K
R50 10K
R51 2.2K
R52 2K
R53 1M
R54 43.2K
R55 680R
R56 1K
R57 200K
R58 10K
R59 1.5M
R60 100R
R61 2M
VR1 10KB TRIM
VR2 100KB TRIM
VR3 10KB
VR4 10KB TRIM* *VR4 was designated as a panel pot.
***OLD VR4--- 10KA "CV Adjust"
VR5 4 X 100KC
VR6 4 x 100KC
VR7 1MB
VR9 10KB
Build notes :
There are pads for an both a SMT and a thru-hole tempco resistor on the pcb the board, install only 1 resistor.
There are a couple errors on the board,
1) the four 2N3904 transistors, need to be installed "backwards" to what the silkscreen suggests.
2) Gate polarity fix, a 2n3904 (or similar) transistor needs to be tacked on to the gate output to convert the original "s-trigger" out to V-trigger out..
Picture coming soon...
3) Pin 12 of the LM339, needs to be connected to the -15v (or -12v) power supply rail. The fix: On the lm339, pin 11 is connected to -15 (or-12v) so you'll have to bend and solder pin 12 to pin 11. The hole on the PCB for pin 12 is connected to the ground plane, so just jumpering the pads on the pcb, will not work. Heres a picture showing it jumpered.
ESP lm339 fix by itsfatmike, on Flickr
4) Tracking fix. This Fix requires 2 trace cuts and two jumpers.
Cut trace on top of PCB between VR2 and pin 14 on lm339, as seen on here,
top trace cut by itsfatmike, on Flickr
Next, make a single trace cut on bottom of PCB between where VR2 and R23,24,27. as seen below, between the top jumper solder points.
bottom jumpers and trace cut by itsfatmike, on Flickr
Finally, solder two wire jumpers as shown in picture above.
Calibration Procedure: (Subject to change)
Step 1:
With no input, Set All knobs to "0"
Adjust "VR1" for 0v at pin 6 of IC3
Step 2:
Connect an Oscillator (VCO1) to the input jack. For calibration, a lower harmonic wave shape like sine is best, but other wave shapes will work.
Adjust gain knob so that the "LED1" just lights up.
Adjust high pass and low pass filters "wide open" (if using a waveform with a higher harmonic, i.e. saw, Adjust the low pass filters to roll of the higher harmonics)
Set "offset knob" to center. (half up)
Connect v/oct output to the V/oct input of a second VCO. (VCO2)
a. Set VCO1 to 55hz (A1)
b. Adjust VCO2 to match the pitch of VCO1.
c. Tune VCO1 to 440hz
d. Adjust VR4 until VCO2 pitch matches VCO1
Tune VCO1 to 55hz
Tune VCO2 to match the pitch of VCO1
Check that the VCO2 tracks VCO1 when switched from 55hz,110hz, 220hz,440hz...etc.
if tracking is off, repeat steps a thru d until ESP has satisfactory tracking.
More coming, but this should get you up and running!
Reese P. Dubin
UG
elmegil
YAY! Will get on this sooooon.
KnobHell
Never mind... figured it out.
elmegil
I've got a 15V system, have any of the values been tweaked for 12V that I would need to tweak back?
elmegil
Next questions :-)
On the Log Amp, I'm not clear on what the frequency adjustment (J5) does. Is it just an offset?
If I don't install the CV Adjust pot, how does the signal get to J6? It looks like J6 comes off the center tap of the pot as does J18?
I have a V/Oct system, but I would like to preserve the option to use the V/Hz output as well.
Questions regarding this:
Can I do both the jumper from J6 to J4 *and* the CV Adjust and V/Hz outputs?
I'm tempted to wire up the Log Amp independently with it normalled to the V/Hz output.... Then I can do other things with it even when I'm not using the ESP proper.... Does that seem feasible?
E.A.S.
yes it works as an offset, it sets the base frequency.
J18 and J6 are in fact connected to the same point on the pcb. The reason J6 exists, is to provide a pad to jumper to J4. Theres a note regarding this on the bottom, right hand side of the wiring diagram. What I didn't note is that you should install a 10k trim pot in place of the panel mount cv adj. pot. I originally just jumpered across the top and middle pot pads, but found i needed some attenuation to the log amp.
Yes.
The CV adjust pot is an output attenuator for the pitch to voltage converter. Just remember with the CV adjust pot installed, adjusting it will mess with the scaling of the v/oct output. (log amp)
This is a great idea. I tried to keep them separate so this would be possible, hence the jumpers.
I have yet to writeup the trimming procedure... coming soon.
elmegil
Excellent, thank you for the quick reply. I was definitely thinking that if I were to use both I'd want to (probably?) set the V/Hz pot to max. If you say it needs a bit of attenuation, I may try to kludge a trimmer between J6 & J4 then.
pedromonkeyfinger
It's peanut butter jelly time! yay! i'm going to order parts now! pretty funny that Korg is actually making these again now It's peanut butter jelly time!
pedromonkeyfinger
I just noticed that with the BOM that C18 and 19 are missing, part of the log amp
elmegil
I can't see 13 or 14 on the silkscreen either.
There does appear to be one unlabeled bypass cap in the same vicinity, I am guessing that's 18, since it's V+ to ground. Per the schematic that's a .1uF
While we're looking at the silkscreen, what's the unlabeled R near the 4 way pot connections?
Edit: well, except 13 & 14 are only on the schematic....
Edit 2: DUR, I see R in the BOM. d'oh!
pedromonkeyfinger
so i've got all the part lined up with mouser except i'm throwing one of these in a euro case and can't figure out what the euro 16 pin power connector is....
elmegil
Waaah waah cry
I have no 12000pF caps (of any sort), no 43.2K resistors, and no 20 pin headers. As you can see I already kludged the 4.3K resistor.
So here is where I stop for a while.... I spose I can work on the panel components and mounting bracket.
elmegil
Here's a revision to the 5u panel I posted in the other thread, taking into account the Log Amp. Using free tools to convert bitmap into vector, so possibly not the best quality.
I've departed from standard MOTM layout, but only slightly....
elmegil
I went ahead and kludged the 43.2K resistor and the 12n cap as well, matched my transistors and I'm basically ready to build my panel. Hopefully this week....
elmegil
Well....
It might look ok until you look closely enough to see
1) several labels too close
2) nearly everything is off center, particularly the tick marks for the pots
3) the nut for the V/Hz input is going to cover the arrow.
Edit: 4) the LED at the top is too close, less than 3/8" clearance to the top rail.
Still, I'm making progress with every new set of mistakes :-)
elmegil
So is the high cut A-D and the low cut E-H ?
elmegil
I assumed I had the two pots correctly identified (A-D/E-H) and have finished the build.
Outstanding questions:
1) What is the calibration for the ESP circuit itself (two trim pots)?
2) What is the recommended calibration for the Log Amp?
3) One of my two 4-gang pots makes a crackling noise when I turn it, and I'm afraid I may have screwed it up somehow--do you have any extras I could repair it with if so? (For cost and shipping, of course).
The knobs aren't nearly as bad as I feared they would be, centering wise.
elmegil
I think the diagram for the frequency offset is backwards. The frequency went up when I turned the knob down, so I've reversed the connections (7.5k to ground and 2.7k to V+ still, just opposite terminals on the pot). Weird though because then higher voltages lead to lower frequencies, not sure what's up with that.
I also wired my LEDs backwards oops ... having them right gives me a better idea how to set input and threshold.
I'm getting a lot of distortion, it seems, particularly the tail of the envelope seems very crunchy. I have a patch I don't want to tear down just yet, so I haven't eliminated the patch itself as a factor.
I'm really excited at the prospect of getting this tweaked so I can play my modular with my bass guitar. I understand my technique will have to adjust some, but even so.... It's motherfucking bacon yo nanners
tobias
I'm in the process of ordering the parts for this from digikey. A little confused though when it comes to the VR section. Does the "B" in VR1 10KB TRIM mean that its a logarithmic trimmer? Or would any 10K trimmer work?
THanks for the help,
Mike
tobias
nevermind, I got my "A" and "B" mixed up
tobias
what good is the v/hz input? When would one need this? Also, if all my vcos accept 1v/oct, is there any reason to include the v/hz output?
emdot_ambient
It's really only good for playing around w/other v/Hz stuff. I plan on just ignoring it.
elmegil
I figure:
1) I don't have any V/Hz equipment, but that doesn't mean a linear rather than expo output couldn't be interesting to use somewhere.
2) Wiring it the way I have, I can use the expo converter for other purposes. I suppose I could save a single jack by not having the V/Hz coming to the front panel, but then there's #1
elmegil
JulianW asked in the PCB thread if I could upload the photoshop files from my panel design. I'm not entirely certain which version he was interested in, so here are both, as .PSD. They're 300dpi, but not vector, because I don't have a good vector solution, and I haven't remade them in FPE. They do resolve the issues I pointed out earlier--LED too high and arrow too close to the jack.
Note also that these are black on white which is how I do my design; inverting them should be trivial for any tool able to read .PSD format.
I'm willing to redo some of this in FPE but I have not done more than start it up and decide I was happy enough for my own process using Photoshop :-)
Page 1 of 4
