Silent Way as a master clock.
Moderators: Kent, os
jonkull
Lowest Common Denominator Patcher
Post by jonkull » Tue Sep 01, 2009 10:50 am
No real point to this post...just an observation.
The one thing I've wrestled with since 'going modular' is how to keep things in sync without falling back on sequencing. I was going to buy a Flame Clockwork then it occurred to me that I can use the Silent Way LFO as a MIDI synced clock source which will make it so much easier to keep things in time than the way I've been doing it.
If only someone would invent a synth that would allow the end user to determine the functionality. You could pick which functions were important to you in 'modules'. A 'modular', if you will. - Stretta
Post by os » Tue Sep 01, 2009 10:58 am
Yup, that'll do it.
Even before the LFO was available, a simple sequenced pattern of notes and the Voice Controller would generate you a nice steady clock source from its gate/trigger outputs.
jonkull
Post by jonkull » Tue Sep 01, 2009 11:47 am
Now I just need the day to go faster so I can get out of work and try this out.
Return to “Expert Sleepers”
