Waveform City TRI vs. SQR output
Moderators: Kent, grantrichter, carygrace
laserpalace
Post by laserpalace » Fri Feb 08, 2013 1:39 pm
Thought this might be worthy of a discussion. It seems that older models of the Waveform City have squarewave outputs in lieu of the triangle output. Mine has a square as well as the older legend (no triangle graphics).
Would it be possible to derive a triangle from the older WFC's? Has anyone attempted this mod? Not sure if it's entirely necessary but it might be more handy for FM duties.
slow_riot
Post by slow_riot » Fri Feb 08, 2013 2:14 pm
Triangle over Square makes much more sense, given the PWM like effects available from the wavetable output. And given the fact that the square is restricted to 50/50 duty cycle only.
I only ever use the main output, but perhaps the triangle would come in useful in a crossfade?
If you knew what you were doing the WFC has the same board as the CVCO (as well as a wavetable board), and it would be very much possible to change your module.
Perhaps see if Cary or Grant are able to help?
chamomileshark
Post by chamomileshark » Fri Feb 08, 2013 3:39 pm
Interesting, didn't know that. Both mine have triangle.
Slow, what did you mean by using the triangle for cross fade - won't that give you FM as it will be at audio rate?
Key Gear: Wiard 300 Series, EMS VCS3, Frac Modular (Blacet, Wiard, Bananalogue & Synthesis Technology).
Pastoral Music: Mark Ellery Griffiths
Music: https://markgriffiths.bandcamp.com/
Website: https://markellerygriffithsmusic.blogspot.com/
Experimental & IDM: Mark Dalton Griffiths
Music https://markdaltongriffiths.bandcamp.com/
Website:https://markdaltongriffithsmusic.blogspot.com/
sandyb
Post by sandyb » Fri Feb 08, 2013 3:50 pm
chamomileshark wrote:Interesting, didn't know that. Both mine have triangle.
not with the wfc in low mode.
slow_riot
Post by slow_riot » Fri Feb 08, 2013 4:07 pm
I meant crossfading between triangle and different waveform, but that would probably be bit redundant on the WFC.
chamomileshark
Post by chamomileshark » Sat Feb 09, 2013 6:49 am
oh ok, thanks.
Return to “Wiard”
