Will this knob fit with my modules?
Author Will this knob fit with my modules?
emergencyofstate
I'm finally gonna do it.
Tom, or anyone else knowledgeable, will these work?
http://www.alliedelec.com/search/productdetail.aspx?sku=70097790
BugBrand
You want these from Small Bear - http://www.smallbearelec.com/servlet/Detail?no=1064
Clones, so a lot cheaper, and these ones are for spline shaft like I use. I've only used a few, think they took a little pressure to get on.. (tried 'em on the PEQ).
emergencyofstate
Thanks Tom.
If I wanted to attempt some color coding would these colored versions work as well?
http://www.smallbearelec.com/servlet/Detail?no=727
BugBrand
You tend to need ones for spline shaft - the set-screw ones are typically a little off centre (due to shaft-size 6mm vs 6.35mm). Works fine for some people though! (Richard, for example) -- or you can add in a little sleeve - think people use burger king straws!
KNYST
I vastly prefer the set screw version. The others are a pain to put on/off - really tight.
But yes you need to make thin sleeves to keep them centered. Like many others, I've done this with my Doepfer modules. Works like a charm.
