Author |
Max4Live device favorites? |
br>dude |
br>does anyone know of a m4l device allowing monome grid control of like midi note info, similar to stretta mabalhabla? br> br> |
br>kirkwoodwest |
br>ignatius |
br>Soy Sos |
br>Thanks Kirkwoodwest,
I need to read more on the manual. This could fix a challenge
for a project I'm developing. You are using it now?
Does is potentially save any or all parameters on any or all
devices (audio/midi/instrument) in a channel strip?
Including Ableton, M4L and 3rd party developers? br> br> |
br>ignatius |
br> Soy Sos wrote: | Thanks Kirkwoodwest,
Including Ableton, M4L and 3rd party developers? |
the manual is here but doesn't say much about 3rd party devices.. vsts etc.
http://www.isotonikstudios.com/Manuals/PPTC%20Manual.pdf
edit..a bunch more info here
http://pp-labs.net/wp/trackpresets/
br> br> |
br>Soy Sos |
br>Here's the quote:
saves parameters of instruments, audio effects and VST plugins (for configured parameters) in a track br> br> |
br>Funky40 |
br>
Thanks !......i´ve overlooked that one so far
if I need to spend 5x 30€ to find one tool that is it for me, it seems still to be a good value, as these tools make my music and my style......
and is it not similar as in modularland: the ones that glue everything together are Gold worth, not ? (still beeing totally new to all this )
personally i see the main investment in the time spent to get into your tools ! br> br> |
br>tommygee |
br>I can recommend K-Devices EXT3 as a brilliant cv modulator source. I bought it yesterday and it works amazingly well with my Eurorack system.
http://k-devices.com/products/ext3/ br> br> |
br>Funky40 |
br> tommygee wrote: | I can recommend K-Devices EXT3 as a brilliant cv modulator source. I bought it yesterday and it works amazingly well with my Eurorack system.
http://k-devices.com/products/ext3/ |
then watch also TIP. they all come also bundled in the modulators pack ( was IIRC 29$ at sales days)
TIP is also a "parameter preset" type of thing.
the problem i just had with Isotoniks pptc is that switching to a preset was knocking out all my modulation tracks. br> br> |
br>kirkwoodwest |
br> Funky40 wrote: |
the problem i just had with Isotoniks pptc is that switching to a preset was knocking out all my modulation tracks.  |
Ooooh that sucks... I would definetly send them a report. Maybe they can fix.. br> br> |
br>pplabs |
br> Funky40 wrote: | tommygee wrote: | I can recommend K-Devices EXT3 as a brilliant cv modulator source. I bought it yesterday and it works amazingly well with my Eurorack system.
can you elaborate a bit on 'knocking out modulation tracks'. just interested what was the prob with our devices in your set.
best,
chris br> br> |
br>Funky40 |
br>JohnnyThorj |
br>Henke Granulator
Midi LFO
Buffer Shuffler br> br> |
br>ignatius |
br>secretkillerofnames |
br>
Fantastic - and excellent integration of Push 2.
br> br> |
br>Funky40 |
br>freebes:
Christian Kleine / Max4Cats
http://christiankleine.com/ck/maxforlive.html
---> ck. tshift / lo-fi pitchshifter ........kind of a grainshift
scroll down, older devices , download part 2
totally like it !......part of my "Rings" patch. undispensable. can add a metallic kind of ringing with size set to CCW or close.
anyway fun with Drums br> br> |
br>Funky40 |
br>freebe: ( probably nothing new to you all)
"Kapture", a "total recall" /"Preset-maker" M4L device
https://liine.net/en/products/kapture/
Quote: | Liine, in association with Minus, are proud to release Kapture for free, a "total recall" Max for Live device developed alongside Richie Hawtin exclusively for his Plastikman Live tour. | br> br> |
br>dataf1ow |
br> secretkillerofnames wrote: |
New to the forums, and I came by to shamelessly self promote this. Great to see I didn't have to! br> br> |
br>tommygee |
br>I'm looking for a very simple Max for Live device: a knob/slider that simply sends out cv. I want to use it automating specific parameters in my modular with my Expert Sleepers EX8. Does anyone know if this simple device exists ?(have tried searching the MFL device database without any luck). br> br> |
br>x2mirko |
br> tommygee wrote: | I'm looking for a very simple Max for Live device: a knob/slider that simply sends out cv. I want to use it automating specific parameters in my modular with my Expert Sleepers EX8. Does anyone know if this simple device exists ?(have tried searching the MFL device database without any luck). |
Create a live.dial, set the attributes such that it generates values between 0 and 1 (range = 0. 1.), connect it to a sig~ and then sent it to the plugin output. Add the knob to the presentation. Done. It's so simple i'm not sure if needs to exist. I could send it to you if you're having trouble with it. But really, it's so easy it could be a nice way to make your first little max for live device. br> br> |
br>tommygee |
br> x2mirko wrote: | tommygee wrote: | I'm looking for a very simple Max for Live device: a knob/slider that simply sends out cv. I want to use it automating specific parameters in my modular with my Expert Sleepers EX8. Does anyone know if this simple device exists ?(have tried searching the MFL device database without any luck). |
Create a live.dial, set the attributes such that it generates values between 0 and 1 (range = 0. 1.), connect it to a sig~ and then sent it to the plugin output. Add the knob to the presentation. Done. It's so simple i'm not sure if needs to exist. I could send it to you if you're having trouble with it. But really, it's so easy it could be a nice way to make your first little max for live device. |
Sweet x2mirko ! i just did the knob - you where right, it's very simple to do. Thanks br> br> |
br>Tristanamo |
br>+1 for AtoVproject Technocity. Stage Sequencer based on the RYK M-185 br> br> |
br>slowpilgrim |
br>Granulator II & Convolution Reverb
Free, to the point, useful, not at all gimmicky like some M4L stuff - these are production tools you can use every day br> br> |
br>alexander92 |
br>If seen it not posted here yet, but I tend to use J74 bassline. Quick and fun for basslines or other monophonic material, you can stay in key if you want, do slides etc.
He has more fun devices check it out(some cost money though):http://fabriziopoce.com/download.html br> br> |
br>ignatius |
br> alexander92 wrote: | If seen it not posted here yet, but I tend to use J74 bassline. Quick and fun for basslines or other monophonic material, you can stay in key if you want, do slides etc.
He has more fun devices check it out(some cost money though):http://fabriziopoce.com/download.html |
they're pretty substantial devices for generating and manipulating melodies, patterns, chords etc etc.. deeply musical things. obviously lot's of work went into his stuff. you can get lost in the devices.. br> br> |
