plumbutter patch sharing thread :D
home of post-70s electronics
Moderators: Kent, bartlebooth
windspirit
Post by windspirit » Thu Jun 06, 2013 7:36 pm
that is an awesome idea I would have never thought of putting audio rate voltages in there
wednesdayayay
Post by wednesdayayay » Thu Jun 06, 2013 9:29 pm
this also works with the snare...
thank you so much for pointing it out!
kozepz
Post by kozepz » Sun Jun 09, 2013 1:40 am
:tu:
more to explore everyday
Krispy
Post by Krispy » Mon Jun 10, 2013 5:25 pm
kozepz I really like the dub track :tu:
kozepz
Post by kozepz » Wed Jun 12, 2013 5:05 pm
Thanks Krispy!
Here's an example of the audio deerhorn trough the blues via the orange back to the green of d'horn.
The gated effect has a nice influence on the delay.
prscrptn
Post by prscrptn » Sat Jun 29, 2013 9:37 pm
^ absolutely beautiful! :tu:
kozepz
Post by kozepz » Mon Jul 01, 2013 2:13 am
Thanks prscrptn!
Its gonna take a while to make some other dubs as Imac decided to give me the white-screen-of-death, and I have no hardware fx.
windspirit
Post by windspirit » Thu Jul 18, 2013 4:34 pm
okay new patch, i call this one the "Psuedoklee" since it is adding together the voltages of all of the states which are on in the sequencer to get changing CVs rather than just on/off. Noise is added for clock randomness, and the internal oscillator of the SAH is used for a continuous tone.
This one uses the gongs for a more dynamic feel, also syncs them to the sequencer.
Keep in mind that since all of these nodes are connected into one node it is easy to avoid stacking 3 bananas by just finding another node inside of the "supernode" to connect to, even if they arent next to eachother on the patching diagram. Also I suggest experimenting with where the noise is patched into the clock.
ALSO this last patch is dependent on keeping a certain amount of feedback in the loop, so if you dont hear anything just raise the Q on the gong that is plugged into the redsteam sequencer input until it makes a steady tone, then the sequencer will have some on positions and you can lower the Q gradually to find a good point.
kozepz
Post by kozepz » Fri Jul 19, 2013 12:28 pm
Nice!
Just tried out the patches!
Although obvious I never patched mwrs with itself, thanks! :tu:
windspirit
Post by windspirit » Fri Jul 19, 2013 5:39 pm
Im not sure its being patched with itself, more just being added together :D thanks though!
kozepz
Post by kozepz » Tue Aug 13, 2013 1:57 pm
Patch:
Quantum dust modulates the fm of the 4/4 gong, when signal enters the comparator, and the gong fm itself.
The same signal has influence on the decay of the snare/hh.
I think its a nice way to throw in some variation in 4/4 rhythms.
In the last part its get controlled by the other gong via the response time.
I've alse tried it via mwrs to make to the duration time longer but I couldnt get that to work.
blue_lu
Post by blue_lu » Tue Aug 13, 2013 2:26 pm
kozeps - amazing music and video. really, really cool! makes me think about picking one of these plumbutters up. keep it up, really inspirational!
windspirit
Post by windspirit » Tue Aug 13, 2013 10:32 pm
plumbutter dance party! no diagram on this one?
kozepz
Post by kozepz » Wed Aug 14, 2013 3:38 am
@blue_li, thanks...dont hessitate, they might be gone before you know it :hihi:
@windspirit, here's the diagram, very simple patch.
The red cable is connected in the end of the video to give a snare sound.
EDIT:
wrong patch image, belongs to the dancing song
I'll have to make it...will upload it this evening
EDIT2:
here's the patch from the video above
phisynth
banana nabab
Post by phisynth » Wed Aug 14, 2013 5:32 am
really cool kozepz :tu:
yeah, I had some fun 4/4 moments with the PB too ;)
may I ask what program do you use to draw these nice patch cables with shadows ?
ph
kozepz
Post by kozepz » Wed Aug 14, 2013 6:07 am
Thanks Phi!
Would love to hear your 4/4 moments :hyper:
I use Illustrator for this, or iDraw on the iPad.
Drop me a note if you need the Illustrator file!
Oldstench
Post by Oldstench » Wed Aug 14, 2013 2:34 pm
Clicky, snare shuffle doo-dad.
The yellow lines indicate approximate knob positions.
Humanity has doomed itself.
windspirit
Post by windspirit » Wed Aug 14, 2013 3:51 pm
Yay! Welcome to the butter :D
kozepz
Post by kozepz » Sun Aug 25, 2013 6:37 pm
Warning: 4/4 monotonous groove :party:
Patch along :)
jdev
Post by jdev » Sun Aug 25, 2013 9:59 pm
kozepz, thanks again for another great PB video and sounds! Nice grooves.
And, will be checking out that new album as well. :tu:
kozepz
Post by kozepz » Tue Aug 27, 2013 3:03 pm
Thanks jdev!
kozepz
Post by kozepz » Wed Sep 18, 2013 10:40 am
What I use a lot to lower avdogs pitch:
patch an unlit orange output from an unclocked mwrs into avdogs purple fm and play with the fm knob
I like the low frequencies, really good for low-droning...
Don't know the theory behind it, but it works!
wednesdayayay
Post by wednesdayayay » Wed Sep 18, 2013 11:03 am
nice! I never even thought of that
I like using the ground on the gongs FM inputs to get some nice low tones
would you mind patching them both up and seeing if they are any different?
Should be getting my coco in a couple weeks
and then I will buy me a pb2 (maybe a dual if I can sell my soundplane)
although I must say if the soundplane doesn't sell before then playing it through the coco will be pretty fun
kozepz
Post by kozepz » Wed Sep 18, 2013 11:39 am
Sure no problem!
What is the ground? I dont have a black nana on mine :hmm:
Guess I am following you.
I was getting a eurorack together, but money wise it would take a long time. Gonna sell all and go totally CL..
wednesdayayay
Post by wednesdayayay » Wed Sep 18, 2013 12:00 pm
can you imagine the fun to be had with a dual plumbutter a nice small room and 4 speakers
i was thinking it would be fun to setup the outputs in an X pattern
let us say that the L and R side of the dual plumbutter have outputs numbered 1, 2 (for L) and 3, 4 (for R)
1 4
-X
3 2
you have a pb2 right? I don't think peter installed ground jacks standard on them. The process to add a ground to the cocoquantus is very trivial so hopefully the same would be the case here
CL all the way
are you located in the US if you don't mind me asking?
Return to “Ciat-Lonbarde”
