909 kick
Discussion for Hexinverter eurorack modules - email Hex if you need anything urgent!
Moderators: Kent, infradead, hexinverter
matic
909 kick
Post by matic » Thu May 02, 2013 9:33 am
Curious to know to know how accurate the 100pf 1kv caps need to be? Mouser is back stocked for months, locally the best I can do is 150pf @ 250v – other options exist with ceramic caps, don’t know which way I should go.
Also the 63v 3300pf, again, mouser is backstocked, locally I can get the wima 3300 at 250v, I assume that won’t be a problem but thought id put it out there..
Any advice is appreciated
hexinverter
the nettles make me think happy times
Re: 909 kick
Post by hexinverter » Thu May 02, 2013 3:51 pm
matic wrote:Curious to know to know how accurate the 100pf 1kv caps need to be? Mouser is back stocked for months, locally the best I can do is 150pf @ 250v – other options exist with ceramic caps, don’t know which way I should go.
Hiya!
Since 150pF is a 50% deviation, I would recommend just using a ceramic cap instead. It'll work just fine :) I'd pick that over using a 150pF.
Yes, the voltage doesn't matter as long as it's above 15V or so. Go for it!
Hexinverter Électronique
em: stacy[at]hexinverter.net
matic
Post by matic » Thu May 02, 2013 8:13 pm
matic
Post by matic » Sun Jun 09, 2013 5:00 pm
Just building this module now. Curious to know if anyone has attempted to add a cv in for the pitch?
hexinverter
Post by hexinverter » Sun Jun 09, 2013 5:18 pm
matic wrote:Just building this module now. Curious to know if anyone has attempted to add a cv in for the pitch?
See the thread in Music Tech DIY :) Someone was asking in one of the more recent pages.
matic
Post by matic » Mon Jun 10, 2013 11:28 am
Will do. Thanks
abelovesfun
Post by abelovesfun » Sun Sep 22, 2013 3:58 pm
Any link to that forum for adding pitch cv? I can't find it via search.
Love my nein-oh-nein kick!
raisinbag
Post by raisinbag » Sun Sep 22, 2013 4:05 pm
No, no one has made one. It can be done (I think with a vactrol and a vactrol board from bridechamber). I may do it for fun at some point
analogdata
Post by analogdata » Sun Sep 29, 2013 5:06 pm
pitch.
I got a pitch that I don't want. The tone just drifts away and back.
Anyone know what could be causing it?
http://soundcloud.com/analogdata/drifting-909-kick
(figured out how to embed soundcloud widget :)
raisinbag
Post by raisinbag » Sun Sep 29, 2013 6:00 pm
Weird. I don't know why it would fluctuate. Just brainstorming, could you have a bad pot? Or solder connection? I can't see schematic on phone for some reason. When hex has a few mins I'm sure he'll give you an idea. What transistors did you use? Sorry I'm useless, I started typing and thoght I could look at circut but I can't. Figured I'd at least finish typing and post.
janost
Post by janost » Mon Aug 25, 2014 1:00 pm
1Kv cap?
Surely that's not needed?
hexinverter
Post by hexinverter » Mon Aug 25, 2014 1:46 pm
janost wrote:1Kv cap?
1000V? No, not necessary of course :P
But, ceramic/film capacitors of the higher end are often very high voltage just due to their construction. They're usually in the hundreds/thousands of volts range when in 5mm lead spacing sizes.
Return to “Hexinverter Electronique”
