Need last bit of explanation
Discussion for Hexinverter eurorack modules - email Hex if you need anything urgent!
Moderators: Kent, hexinverter
jmcecil
low order biterness
Post by jmcecil » Fri May 24, 2013 7:20 am
Finishing up my first ever DIY projects! I'm waiting on a header delivery so that I can jumper most of the connections instead of soldering. Anyhow, I have to make the decision for 5V, Vcc or 10V. I get 5V.
10V: I was expecting -5/+5 for bypolar type stuff. Is this 0-10? If so, what does that work with?
Vcc: No clue. What is a usage?
I'm really happy how these came out.
music noun, often attributive
: personal interpretation of ones auditory experience beyond basic sound recognition
: anything that makes your parents say "turn that shit down"
hexinverter
the nettles make me think happy times
Re: Need last bit of explanation
Post by hexinverter » Fri May 24, 2013 9:16 am
jmcecil wrote:Finishing up my first ever DIY projects! I'm waiting on a header delivery so that I can jumper most of the connections instead of soldering. Anyhow, I have to make the decision for 5V, Vcc or 10V. I get 5V.
Very nice builds! :)
To answer your queries:
sympleSEQ is very, uhm, simple...since it is comprised of CMOS logic chips, it outputs 0-~10V by default. Shifting it to a different voltage (ie: -5 to 5V) would mean more parts.
In any case, you can make anything you are modulating respond to 0-10V as if it was -5 to 5V by applying a 5V offset to it. That is, with a VCO or whatever you just turn the initial setting for the thing you are modulating up :P
So, 0-10V is very useful. :tu:
Also, note data is very often not negative voltages!
"Vcc" means the supply voltage. If you're powering with 15V, it means that output goes as high as almost 15V.
Hexinverter Électronique
em: stacy[at]hexinverter.net
jmcecil
low order biterness
Post by jmcecil » Fri May 24, 2013 9:28 am
Ahhhhhhhh Vcc is whatever voltage being fed.
I'll probably use 10V as default then. I guess making the CV jack hookup using a jumper is a good idea so I can switch around easily.
I'm also going to normal the clock out from one of them to a Yusynth Divider behind the panel. Should be a cool setup.
They actually are pretty powerful for 1U. The only major thing missing is gate width.
hexinverter
Post by hexinverter » Fri May 24, 2013 10:23 am
jmcecil wrote:Ahhhhhhhh Vcc is whatever voltage being fed.
Hehe right on!
Yeah it would be nice to have gate width but that's a whole 'nother can of worms!!! It would greatly complicate the circuit actually.
Return to “Hexinverter Electronique”
