How do you use your Doepfer LPG (A-101-2) ?
Moderators: Kent, lisa, luketeaford, Joe.
440hz
Post by 440hz » Tue May 28, 2013 2:16 pm
Sometimes, I see in this forum that a LPG should produce its distinctive sound by just putting a gate as CV input. Tried that in CV1 and CV2 of the Doepfer LPG : nothing interesting.
How (which path) do you achieve this "natural attack sound" through a Doepfer LPG? Is there a secret?
Or have I a problem with mine?
rjungemann
Post by rjungemann » Tue May 28, 2013 2:22 pm
Try a quick envelope instead. LPGs with shorter decay times sound better with a quick envelope going through them.
Rigo
Chief Spam Killer
Post by Rigo » Tue May 28, 2013 2:26 pm
Don't forget that there is quite some variation in vactrol behaviour, so don't be surprised that you cannot get exactly the same as somebody else is getting.
And if you have some spare random gates available: use the G1 and G2 inputs with the switch in the middle position to randomly change the behavior (LPG/VCA/Both) ... I don't think there is another LPG that allows you to do this.
440hz
Post by 440hz » Tue May 28, 2013 2:30 pm
rjungemann wrote:Try a quick envelope instead. LPGs with shorter decay times sound better with a quick envelope going through them.
Have you got an example on how it sounds on yours?
jtmmorrow
Post by jtmmorrow » Tue May 28, 2013 2:33 pm
Sine in audio, just about any gate in cv2, works for me.
"You're just a wave/ You're not the water" Jimmie Dale Gilmore
Post by exper » Tue May 28, 2013 2:34 pm
The fact is, the a-101-2 has the fastest vactrol response I've ever heard. It's almost non-existent. So you really still need to use an envelope with it. Contrast it with an optomix or Borg 1, both of which have a much slower vactrol sound. A trigger into either of those creates a nice long, natural sounding decay or ring.
FS/T: Goike 12u/104hp Bamboo/Aluminum Folding Case
poppinger
Post by poppinger » Tue May 28, 2013 6:50 pm
Yeah the A-101-2 response is quite quick. I have a A-142-4 Quad Decay sitting right next to mine which I find to be a perfect companion. If I get a chance I'll try and record a bit tomorrow.
John Noble
Pining for the fjords
Post by John Noble » Tue May 28, 2013 7:55 pm
exper wrote:The fact is, the a-101-2 has the fastest vactrol response I've ever heard. It's almost non-existent. So you really still need to use an envelope with it. Contrast it with an optomix or Borg 1, both of which have a much slower vactrol sound. A trigger into either of those creates a nice long, natural sounding decay or ring.
Interesting, I find the subjective "speed" of my Optomix to be "faster" than any of my three A-101-2s in "both" mode. I think the Optomix opens the filter sooner or something, but it definitely feels snappier.
Edit: to the OP, almost everything in my Soundcloud tracks was done with A-101-2s. Only the last couple of tracks have some Optomix in them.
Go make some music.
http://prettyhowtown.net
Post by exper » Tue May 28, 2013 8:30 pm
Well, attacks can vary, but to be, most of the characteristics of a LPG is in the decay. The natural slew that happens to a trigger input. Fast-USB attack, slow decay.
John Noble
Post by John Noble » Tue May 28, 2013 9:41 pm
exper wrote:Well, attacks can vary, but to be, most of the characteristics of a LPG is in the decay. The natural slew that happens to a trigger input. Fast-USB attack, slow decay.
Yes, I mean on both sides of the peak.
Go make some music.
Post by exper » Wed May 29, 2013 6:13 am
I agree with you. In fact. That's why I just ordered the new dual Borg. The Optomix almost has a harsh attack. Sometimes it even clicks unless you dial in your envelope attack.
oisin
Re: How do you use your Doepfer LPG (A-101-2) ?
Post by oisin » Wed May 29, 2013 7:37 am
440hz wrote:Sometimes, I see in this forum that a LPG should produce its distinctive sound by just putting a gate as CV input. Tried that in CV1 and CV2 of the Doepfer LPG : nothing interesting.
just to make sure - do you have it on LP function with the resonance cranked up? sometimes i have to fiddle with the F/A range too to get it to really sing.
felixer
Post by felixer » Wed May 29, 2013 10:56 am
jtmmorrow wrote:Sine in audio, just about any gate in cv2, works for me.
+1 :tu: it's more of a woodblock than a bongo. nice, 'ploppy' sound. to me the attack is prob more importent then the decay. that i can easily simulate with an env. but the sound of the attack ...
res@max
random gate to switch between gate/lpg :party:
don't need midi, don't need keys, just want knobs and cables (all together now ;-)
440hz
Post by 440hz » Wed May 29, 2013 2:54 pm
This is a sine in the Audio-In
F/A : 0
CV 2 : connected to an enveloppe with no attack
CV 2 pot : put to 10 and decreased in the demo
Do you have something similar?
jtmmorrow
Post by jtmmorrow » Wed May 29, 2013 6:09 pm
Mine is more like woodblock, as felixer notes above. Maybe a shorter gate/pulse width would help. I usually use Rene or Pamela' Workout, without an envelope.
I am away from modular and computer for a bit. Good luck.
proturboplus
Post by proturboplus » Thu May 30, 2013 3:24 am
poppinger wrote:Yeah the A-101-2 response is quite quick. I have a A-142-4 Quad Decay sitting right next to mine which I find to be a perfect companion. If I get a chance I'll try and record a bit tomorrow.
Hi,
as I wrote in another thread, I'm very interested whether the doepfer lpg can produce bass drum like sounds (I guess so if the response of the vactrol is faster than other lpgs).
If you could include these sounds in your demo it would be awesome! :-)
Etan
Post by Etan » Thu May 30, 2013 11:00 am
Yes, a-101-2 is capable of producing very wide range of bass drum like sounds. It is not always easy to get there instantly, you have to tweak the knobs for a while since the sound is very dependant on resonance and freq settings, cv modulation intensity and the type and level of the input signal.
Also the trick I like to use is to feed envelope into audio input, low frequency value and then tweak the resonance knob until it "rings" in the low end.
440hz
Post by 440hz » Thu May 30, 2013 3:04 pm
Envelope into audio input?
felixer
Post by felixer » Thu May 30, 2013 9:43 pm
proturboplus wrote:whether the doepfer lpg can produce bass drum like sounds
ooohhh yes. and bloody loud too :twisted:
John Noble
Post by John Noble » Thu May 30, 2013 11:36 pm
:agree:
Go make some music.
Etan
Post by Etan » Fri May 31, 2013 1:10 am
Is that so weird? It has to be a very short envelope, no sustain and no release, just attack for transient adjustment and decay for length, we are talking about very low values. Similar to pinging the filter with triggers. Try it out, also with some other filters, you can get some cool drum sounds.
proturboplus
Post by proturboplus » Fri May 31, 2013 2:41 am
:agree:
Great - that's exactly what I wanted to hear!
Still... any examples, someone? :razz:
poppinger
Post by poppinger » Fri May 31, 2013 4:11 am
Gates through a sequential switch swapping between LP/Both/VCA mode-- Around 13 seconds in, I change the switch to 3 steps instead of 4 so it plays against the 4/4 sequence. It's a great way to subtly change it up and make it sound more polyrhythmic without changing the timbre all that much.
http://soundcloud.com/poppinger/a-101-2-blips
Basic kickdrum patch with A-101-2 as the sole sound source:
http://soundcloud.com/poppinger/a-101-2-kickdrum1
12u spaghetti kickdrum patch with A-101-2 as final LPG:
http://soundcloud.com/poppinger/a-101-2-kickdrum2
southphillysynths
Post by southphillysynths » Fri May 31, 2013 5:17 am
Raul did a pretty extensive series on the Doepfer LPG. Goes into lots of different uses! :tu:
Dcramer wrote:"Not all who wiggle are lost" :boat:
WHO IS BOZO TEXINO?!?!
proturboplus
Post by proturboplus » Fri May 31, 2013 8:00 am
Hi poppinger,
thank you so much for your demos, they sound great! I think I am convinced. :guinness:
However, I've noticed that quite some modules are involved in creating these bass drum sounds. My question now would be, is it possible to great bass drum sounds by just using the lpg and maybe an envelope or better just a trigger?
I was thinking about adding a TTA BD808 to my setup, but the lpg seems way more interesting/versatile (of course not only for bass drums)...
