New Plan B stuff announced Monday
Moderators: Kent, lisa, luketeaford, Joe.
- My codename's Happy Harry, I'm Into CV
From the Plan B yahoo group:
In case you didn't see this before, on Monday morning we will be
posting photos and product descriptions of the following, all of which will be
released between June and September of 2008:
ELF Series:
Model 23 Analog Shift Register
Model 36 Leveler
Model 37 ELF LFO
Model 38 ELF ADSR
Model 38A ADSR Expander
Model 39 Wave Splicer
Model 40 Headphone Preamp
Standard Series:
Model 21C Mini Milton (18hp)
Model 30 Triple Digital VCO Subsystem (26hp)
Model 30C Expander for Model 30 (8hp)
Model 31 Buffered Multiple (6hp)
Model 32 Vector Plotter (14hp)
Model 33 Triple VCA (10hp)
Model 34 Switch Logic (10hp)
Model 35 Vector Switch (10hp)
ELF Series:
Model 36 Leveler
Model 37 ELF LFO
Model 38 ELF ADSR
Standard Series:
- a100user
- All the gear, no idea!
Here it is, some great looking modules.
I particularly like the Vector switch and plotter
http://www.ear-group.net/08new.html
- whyterabbyt
- Common Wiggler
- Muff Wiggler
- wait, what?
I'm in love with the mini-Milton...which I will henceforth call Milton Jr. because I think it sounds cooler.
- Chuck E. Jesus
- holier than thou
- Chuck E. Jesus
- holier than thou
- Chuck E. Jesus
- holier than thou
- consumed
- International Filter Conspiracy
well, i just checked peter's post about all the configuration options on the new m30. this looks like a really powerful module.
Peter wrote:The Model 30 is configurable. This is the basis of the 'subsystem'
paradigm. The intent was not to approach this as three VCOs - although
in MINI MODE Patch 1 it is exactly that), but more a subsystem of
three VCOs in which complex timbres can be realized. This is the main
reason for having only 1 output.
By selecting a patch, the output configuration is changed to reflect
any one of ten internal patches (let's not use the word algorithms,
please. 1, it was a lame description to begin with, 2, it suggests a
connection to DX technology, which the M30 surpasses). These patches
are broken into four categories:
"MINI" MODE (meaning they replicate classic analog patch
configurations with MINI in reference to the MINIMoog).
FM MODE - patches which deal primarily with internal Frequency Modulation.
RING MOD MODE - The output is configured as a Four Quad. Balanced
Modulator or Ring Modulator.
FREQ SHIFT MODE - The output is configured to provide Frequency
Shifting of two or more of the VCOs.
Each mode has a series of series of patches available to the user.
Looking at the MINI MODES:
The first is classic Three VCOs through a Mixer. Yet remember, each
of the inputs to that mixer have full voltage control as well as
manual levels, so more three VCOs into three VCAs into a mixer.
The second patch in the category removes VCO1 from the output and
routes it to FM 2 and 3. There are actually two paches represented
here. In one the FM to VCO 3 is in quadrature (thus 90 degrees).
FM MODES:
In the first patch VCO 1 is removed from the output and used to FM
VCO2. VCO 3 is unaffected and passes straight to the output.
In the second, VCO 1 FM's VCO2 and the output of VCO2 FM's VCO3.
In the third, both VCO1 and VCO2 are routed to FM VCO3.
RING MOD MODES:
Patch 1: VCO 1 FM's both VCO2 and VCO3, with VCO's FM in quadrature.
The Output of 2 and 3 are then balanced modulated.
Patch 2: VCO 1 and VCO2 are Bal. Mod, VCO3 passes straight to the
output unaffected.
Patch 3: ! and 2 are Bal Mod, and that output is routed through a
second Bal Mod with VCO 2.
FREQ SHIFT MODES:
Patch 1 gives the DIFFERNCE output of VCO 1 and a summed yield of VCO
2 and 3 running in 90 degree phase relation to one another.
Patch 2 is the same but outputs only the SUM of the two
There are a few things to remember here:
1) At all times the LEVEL pots and VC LEVEL inputs to the three VCOs
are live. One can effect the dynamics of anything you see in these
diagrams.
2) While patch configurations effect internal routing, they do not
send the panel controls to preset levels. In short, this module
behaves like an analog VCO bank. In this way sound design decisions
were not made for you, they are made by the end user
3) The Patch pot is fully voltage controllable. In this way, M30
'hearts' M21C.
4) Along with any internal FM represented by the patches, the user retains use
of the PHASE LOCK (sync) the external individuals VCOs FM inputs as well.
There are some patches where these functions are altered, we will get to this a
bit later.
5) Oh...this is just like a DX7, right? Wrong! Remember not only
does the user retain full control of the Waveshape of each VCO in
realtime, but their phase relationship to one another within the patch
(quadrature). Try THAT one on your DX.
Yeah I'm really excited about the M30 now. When Peter was showing me the prototype at NAMM (and it was just showing...it wasn't plugged in or anything) a lot of these routings hadn't been finalized yet.
He mentioned the obvious mini mode and FM modes, but I had no idea there would also be ring mod and freq shift possibilities!
I think this will definitely be another module to the system...sound samples will sell me on it for sure.
Probably pretty crazy!
I'm curious to eventually hear some sound samples and hear the amount of aliasing present.
A certain amount of aliasing can present a unique timbrel flavor, but too much aliasing might be a bit annoying...
geez, listen to me...heh...all spoiled on analog audio rate modulation
Peter announced ELF pricing on the Plan B list this morning:
The pricing of the ELF products have been finalized:
Model 23 Analog Shift Register: $165
Model 36 Leveler: $60
Model 37 LFO: $160
Model 38 ADSR: $130
Model 38A ADSR Expander: $55
Model 39 Wave Splicer: $100
Model 40 Headphone Preamp: $75
They will be shipping in late June, possibly early July depending on
the ramp-up time of the first production lot.
The Plan B site will be updated to include product pages for the ELF
series within the next week and preorders will be available through the Noisebug
site within the next two weeks.
