NON Snare ZTX1051A
Discussion for Hexinverter eurorack modules - email Hex if you need anything urgent!
Moderators: Kent, hexinverter
lucid
NON Snare ZTX1051A
Post by lucid » Thu Jun 06, 2013 9:21 am
from assembly quide
The ZTX1051A are a different pinout than the BC549, so be careful of that!
They are commonly available but sometimes are out of stock, so, if you
need, you can use standard NPN 2N3904 in their place with not too much
ill-effect :)
"not too much ill-effect" can you explain it? How much it will affect sound of NON snare?
It is available from Mouser, so there is chance to get it. Thats why I dont want to sacrify specific sound of NON snare if any.
But if difference is not noticable at all, I will use 2N3904.
milan
hexinverter
the nettles make me think happy times
Re: NON Snare ZTX1051A
Post by hexinverter » Thu Jun 06, 2013 11:30 am
lucid wrote:from assembly quide
ill-effect :)
milan
I haven't done scientific tests nor have I used anything but the ZTX in my builds, so, if you're at all concerned, don't use the 2N3904. Every 909 sounds subtly different than every other 909 (as is the case with the 808 as well). So a discerning ear will be able to tell the difference between two models even if they use the same parts. If you are one of those people, don't use substitutes :)
Hexinverter Électronique
em: stacy[at]hexinverter.net
lucid
Post by lucid » Fri Jun 07, 2013 10:51 am
OK thanks
than I will try 2N3904, maybe later will change to ZTX if I will feel that something is not that good as I think it should be. :hmm:
hexinverter
Post by hexinverter » Fri Jun 07, 2013 10:56 am
lucid wrote:OK thanks
Right on! Best of luck :tu:
Return to “Hexinverter Electronique”
