Wow and flutter delay input
MUFF WIGGLER Forum Index -> SNAZZY FX
Author Wow and flutter delay input
HIMA
so i was hoping that when i jacked a modulation source in there it would give the awesomeness that happens when i manually twist the delay knob. no such luck. it seems to have only the slightest effect.
i'm a relative noob so i tried all kinds of things. i pumped the signal strength, think perhaps it needs 8 in and i'm only sending it 5... no diffs.
i even wondered if perhaps it was an out put that sent a cv for the delays current setting...
it's not.
so, is this what's supposed to happen? the very slight shift in delay value?
thermionicjunky
Just to be sure, are you using the depth knob to control the modulation level?
HIMA
The Agonizer! i'm a dumbass The Agonizer!
depth = attenuator for delay input?
loss1234
YES!!
see my new post
the DEPTH KNOB IS THE DELAY CV INPUT DEPTH KNOB!!
TURN IT TO 10
