Calibration 258v
Author Calibration 258v
pjoris
How do I calibrate the tracking on the 258v, there are 4 trimmers/oscillator (see pics)- which one to turn ? I want to use the gray inputs to track my Kilpatrick pattern generator. Just the trimmer closest to the gray input ?Thanks, Joris
sascha.victoria
Isn't there a trimmer you can access via the front panel?
chrisso
If you are using the Buchla version of the Kilpatrick, there are also trimmers on that output.
So I would check the scaling of your 258v aside of the Kilpatrick first. If your 258v tracks correctly, try adjusting the Pattern Generator instead.
pjoris
I used the trimmer on the kilpatrick already to let the 261e track, and anyway the top and bottom oscillators of the 258v tracked slightly differently. I used the trimmer closest to the grey input and got it to track already a bit better, but so nobody has a full calibration routine for the 258v ? Thanks, Joris
chrisso
Send an email to Mark Verbos.
reverberation
Any updates/thoughts regarding this?
Just got a 258v and it tracks really shitty.
Will go to the studio tomorrow and try to calibrate it.
