pt delay 2011 question
Author pt delay 2011 question
mayanspring
does anyone know if the pt delay ext punch input can be controlled via CV triggers or gates instead of a foot switch?
and the toggle time for that matter...
BugBrand
You just need a V-trig to S-trig converter - you can fit the 3 components in a jack plug - http://www.retrosynth.com/docs/trigger/
mayanspring
so I take it there is a diode, a resistor and a transistor. but I am a little thrown off by the connections between ground and tip. any advice on how to lay that out? (sorry I know this is not the DIY forum here...)
BugBrand
Based on this one..
Plug which goes into the PT Delay has:
Tip - from the top of the transistor (collector)
Sleeve - connect with other ground points
Plug/socket which comes from your modular has:
Tip - goes to 10k resistor
