ate-oh-ate-nein-oh-nein output level controls
Discussion for Hexinverter eurorack modules - email Hex if you need anything urgent!
Moderators: Kent, hexinverter
neandrewthal
full clout y'all
Location: Spending warm summer days indoors writing frightening verse to a buck-toothed girl in Luxembourg
Post by neandrewthal » Wed Jul 17, 2013 4:43 pm
Do the output level controls on these projects do anything besides control the volume, like make them distort or sound different or anything like that? I'm just wondering if it's a good idea to omit them if I'm running all my drum modules into a mixer after anyway.
Initiate the sequence, create catastrophe.
hexinverter
the nettles make me think happy times
Re: ate-oh-ate-nein-oh-nein output level controls
Post by hexinverter » Wed Jul 17, 2013 5:35 pm
neandrewthal wrote:Do the output level controls on these projects do anything besides control the volume, like make them distort or sound different or anything like that? I'm just wondering if it's a good idea to omit them if I'm running all my drum modules into a mixer after anyway.
Hiya!
Nope, the controls just modify the output volume for each of the circuits.
However, each of them does it differently...so, if you plan to omit them, you will need to study and alter each circuit so that they simply output unity gain volume at all times.
For example, the method of volume control in the 808 cowbell is completely different than the 808 hihats. So, it's not just a matter of omitting an attenuator on the output of each module or something trivial like that.
If you want to create a dedicated drum mixer for all these designs, I suggest instead making your mixer unity gain and then using the level controls already on each module to control the volume of each element in the mix!
Hexinverter Électronique
em: stacy[at]hexinverter.net
neandrewthal
full clout y'all
Post by neandrewthal » Wed Jul 17, 2013 9:28 pm
Thanks, I'll ponder the issue.
rosch
roadkill
Post by rosch » Fri Aug 02, 2013 4:29 pm
wouldn't it be the easiest way to just bridge 2 pads of the volume pots so it's always cranked up and then omit the pot?
hexinverter
Post by hexinverter » Fri Aug 02, 2013 5:48 pm
rosch wrote:wouldn't it be the easiest way to just bridge 2 pads of the volume pots so it's always cranked up and then omit the pot?
Sometimes the pot is acting as a voltage divider, sometimes it is controlling gain, etc...so it depends on the circuit. Like I said, each one is different! Study the circuit and the answer will come to you :)
rosch
roadkill
Post by rosch » Fri Aug 02, 2013 6:03 pm
alright - but if you turn it all the way up that's what you do: short one side.
so if one wanted to be sure to do it right without studying the theory they should be fine shorting one side and putting a resistor with the pot's value from wiper to the other side.
KnobHell
Post by KnobHell » Fri Aug 30, 2013 10:35 am
Stacy, you should add a single mixer to all the 808/909 modules so you can daisy chain them together.
ps. Just finished my Kick drum, sounds awesome!
pps... Now I need another mixer, you can never have enough!
Misspelling: brought to you by autocorrect.
The KnobHell Website
KnobHell Soundcloud
KnobHell Youtube Channel
hexinverter
Post by hexinverter » Fri Aug 30, 2013 4:31 pm
KnobHell wrote:Stacy, you should add a single mixer to all the 808/909 modules so you can daisy chain them together.
Hehe woot :cloud:
Well yeah, it would be nice! I've thought of making a nice little mixer expansion module for all of them with panning and stuff. Too much other stuff in the works though and not enough time, so it's very far down on the backlog...
Return to “Hexinverter Electronique”
