Malekko Bananable?
Reese P. Dubin
Malekko Bananable?
Post by Reese P. Dubin » Mon Oct 26, 2009 11:08 am
Malekko is looking pretty tasty with all this Wiard stuff. So are these modules real modern style with all the jacks being PCB mounted, or can I rejack them with bananas and set them free? Switching jacks and all of that are not an issue.
tragedybysyntax
Banned until Restitution Made
Post by tragedybysyntax » Fri Oct 30, 2009 10:29 am
+1 for fingers crossed?
- [ Custom Metalwork ] -
BananaPlug
Post by BananaPlug » Fri Oct 30, 2009 10:52 am
I looked at the Borg. If I bend the jack's solder tab over and slip some kind of bushing, like O ring, between the jack and the front of the panel there should be just enough clearance. That's with the standard Johnson banana jack. I'm only running 1 row of euro at the moment. When I get some more room I'll try it.
revmutt
Knutty For Knobs
Post by revmutt » Fri Oct 30, 2009 8:51 pm
Not having noticed this thread I just tried to run a sequence from the 250e into the Anti Oscillator via the Format Jumbler.
Interestingly it was the only oscillator that I tried that worked fine without any major attenuation. On the test floor was an AFG, M15 and Classic VCO -the last was a bit of a mystery as to why it wouldn't work.
Bare in mind, I'm not a math guy I play bass.
Tommy DOG
Punk Rock Star, gambler and stunt double
parasitk
Learn to swim
Post by parasitk » Fri Nov 20, 2009 11:42 pm
I'm guessing no one has actually converted their Malekko Wiard modules yet to banana? 'Cause I'm curious about this too...
...for no particular reason! :ninja:
Malekko
:super awesome ninja:
Post by Malekko » Fri Nov 20, 2009 11:57 pm
it would be way more trouble then what it's worth, you's have to find another way to mount the PCB..as the jacks are the anchor to the faceplate...
:deadbanana:
parasitk wrote:There are a lot of talented synth designers here, but I'm sorry to say that none of them invented the triangle.
parasitk
Learn to swim
Post by parasitk » Sat Nov 21, 2009 12:02 am
:sadbanana:
BananaPlug
Post by BananaPlug » Sat Nov 21, 2009 3:52 pm
:tu:
panda30y
Post by panda30y » Sat Nov 21, 2009 4:08 pm
Very nice. :yay:
DGTom
Post by DGTom » Sat Nov 21, 2009 9:50 pm
BananaPlug cares not for can't!! :hail:
parasitk
Learn to swim
Post by parasitk » Sun Nov 22, 2009 1:23 am
:banana:
I'd like to know more about how this was accomplished! :cloud:
BananaPlug
Post by BananaPlug » Sun Nov 22, 2009 12:31 pm
parasitk wrote::banana:
I've put the details in this thread but if a moderator has a better place for it go ahead and move it.
mono-poly
Le Cheff
Post by mono-poly » Sun Nov 22, 2009 12:53 pm
Bananaplug could you pust a pic off your whole bananfied setup?
Including the stuff witch was banana by origin.
The farad is the captain of my print.
http://www.mono-poly.nl
http://www.noodlebar.org
WTB blue lantern purple vco
BananaPlug
Post by BananaPlug » Sun Nov 22, 2009 2:47 pm
Well, it's in an in-between state right now. Originally it was Serge panels in a curved console. Years later I built a dual rack, like an Ikea book case, so I could mix in other formats. I tried some Modcan A and quickly decided that Serge and Modcan (Cynthia too) would become the core and I'd limit the Frac and Euro to special things.
The plan is to reconfigure into something less tall. Make a block of Modcan in sixpacs (that's done), set that on a 27" wide box with 1 row of Frac and 1 row of 1 Euro and divide the Serge putting some of it flat on the table (TKB goes there for sure), and the rest in a rack to the side. Might use Tourcase cases for the stuff on the sides. Had hoped to get Randall to make the wide 3U case but I chickened out. Also have DIY underway in the A format. Sometime this winter I'll have pictures.
