[ORDER] Euro panels for Barton VCA/Mix and Waveform Animator
Author [ORDER] Euro panels for Barton VCA/Mix and Waveform Animator
sempervirent
VCA/Mix panels are almost here so I wanted to update the thread. Seq Switch panels have sold out. Now taking requests for other Barton panels, just comment or send a PM.
Barton VCA/Mix
http://www.bartonmusicalcircuits.com/vcamix/
http://grayscale.info/panels/barton-musical-circuits-vca-mix/
Barton Waveform Animator
http://bartonmusicalcircuits.com/saw/
http://grayscale.info/panels/barton-musical-circuits-waveform-animator  /
Fonitronik Sequential Switch - sold out
http://www.modular.fonik.de/Page32.html
http://grayscale.info/panels/fonik-fonitronik-sequential-switch/
keninverse
Yessss....
I've been playing around in FPD for a few waveform panels. Thanks for doing this panel run. The VCA/mixer panel will definitely be on the short list as well.
spneca
Pre-ordered a Waveform Animator. Thanks!
logicgate
Thanx a lot mate!
Good thing that the pre order is open til the 1st of October! Better for me Mr. Green
negativspace
Into the switch, but is it sized for Cliff jacks? (If so I may pass. I passionately dislike Cliff jacks.)
neandrewthal
sempervirent wrote:
Fonik says it's no problem to do another run of boards if there's interest.
Here's the thread for the last run if anyone wants to chime in with their interest:
https://www.muffwiggler.com/forum/viewtopic.php?t=51512&start=0
I would love to see more boards get made, though I'm building in 5U so I wouldn't buy any panels.
fonik
yep. the thing is that the PCB layout provides footprints for the cliff sockets, so the PCB can be mounted easily to the front panel.
i did another version with vertical PCB mounted front panel components, however, it was SMT.
negativspace
Yeah, I know why they're there. I've built a couple that still need panels! I just can't do the Cliffs. Did one module with them a few years ago and it's a total horror show. Kick drums of sufficient volume cause intermittent contact, and i don't even have a subwoofer. Some of the jacks have failed entirely. Dead Banana
That plus I keep Kobiconns on hand by the thousand. hihi
negativspace
Maybe the jacks from the recent group buy will fit? I like those. Not too worried about mounting, I'll do the necessary work to convert.
xonetacular
I don't mind cliff jacks as long as it is PCB mount. My dislike of cliff jacks is overshadowed by my hatred of panel wiring. hihi
I might be in for a board.
Synthsense
2 W.Animator panels + 2 Seq Switch Panels for me, please CHEERS! Guinness ftw!
sempervirent
Weekend bump.
As I mentioned to Synthsense via PM, all ordering is done through the website, I gave up on doing orders via the PM system after just a couple of group buys.
sempervirent
Another bump, about two weeks left to order these.
mOBiTh
i've ordered so many panels i can't remember what i've ordered hmmm.....
sempervirent
Ha! I'll check on it and send you a message.
sempervirent
Bump, still taking preorders for these, Sequential Switch will close on Oct 1, might leave the Barton panels up for a big longer since I just added the VCA/Mix.
frozenkore
Will you be ordering any extras?
sempervirent
Yes, I usually get a few extras, but I don't plan to keep a lot of them on hand indefinitely. With DIY projects everything depends on PCB availability.
sempervirent
Bump, preorder cutoff for Sequential Switch panels is this Tuesday (October 1). I'll hold out on the Barton stuff a bit longer since I just recently added the VCA/Mix.
sempervirent
All panels have been ordered, I will have about 5-10 extras of each panel.
sempervirent
Still have a few panels left:
3 x Barton VCA/Mix
6 x Barton Waveform Animator
8 x Fonik Sequential Switch
sempervirent
It's been a while, just wanted to post an update...
VCA/Mix panels will be here on Wednesday, there was a factory error and they had to be remade, which took a few extra weeks. I have Waveform Animator and Seq Switch panels here. Seq Switch panels have sold out however.
People have been asking for other Barton panels too, and I see that Michael has added drill templates for most of the modules, so offering these should be fairly simple. If anyone has requests, just let me know.
regenbot
I'd love a panel for V2R http://www.bartonmusicalcircuits.com/v2r/
qfactor
Sempervirent,
I believe I've pre-ordered the VCA/Mix and SeqSwitch from you already, but 1 question, is the trigger button size for the SeqSwitch panel 1/8" size? I'm referring to the hole in the panel for the button. hmmm.....
Jonachi
Barton Voltage to Rhytm-converter please!
