"The MOS Technology 6581/8580 ‘Sound Interface Device’ chip, aka the ‘SID’, was the sound generator chip used in the Commodore 64 home computer – the greatest selling home computer of all time. The SID, by the means of 3 wavetable oscillators, a real analogue multi mode filter, an ADSR and various cross modulation options, provided the soundtrack to a generations gaming and perhaps many peoples first exposure to real sound synthesis. The SID’s unique musical aesthetic has lasted well beyond the lifetime of the C64 re-imagined in standalone products such as the SID Station and with in the computer via sophisticated software emulation.
The SID GUTS now takes the legendary SID chip and tailors it into the eurorack modular environment. By use of a real SID chip the classic sound is taken in a new direction with the levels of direct and voltage control only a modular system can offer.
The SID GUTS provides a single ‘SID Voice’ to your modular. The charm and authenticity of the original sound is preserved with no attempt to ‘clean’ or reduce noise in the SID audio output."
The SID GUTS supports to following SID chip features via modular control;
-1volt per octave control of a ‘core’ SID oscillator 0-5v input (with tunable offset covering 8 octaves in total)
-Direct and voltage control of oscillator wave shape selection (Pulse, Triangle, Square, Saw).
-Filter switchable between 4 modes - 12dB/Octave HP , LP , BP & Notch (HP+LP).
-Direct and Voltage control (with offset) of Filter cutoff and Resonance.
-1 volt per octave control of second SID ‘modulation’ oscillator.
-Direct and voltage control of modulation oscillator ‘type’; ring modulation, sync or none.
-Direct and voltage control of pulse wave pulse width.
-External audio input.
The SID GUTS does not support the following SID features;
-Remaining 3rd oscillator (Inflexibility due to shared output and impact on module size+cost.)
-ADSR (its buggy and pretty rubbish really.)
Other features include;
-Support for ALL SID chips (6851/8580) & SwinSID chips.
-All settings non volatile.
-Audio output and input at modular levels.
-Designed and built in England.
Technical Specifications
Supply: +/-12V (Reverse voltage protection)
Current Draw: ~50 - 200ma (dependent on SID chip used)
Depth: 30-40 mm (with heat sinks installed)
Please note vintage SIDs are a very old technology - they run pretty hot and pull a lot of current. You want a case with plenty of airflow and available power. I recommend the use of SwinSID's to avoid such issues!
Video
Availability
There is an initial factory built run of just 50 modules available in next few weeks. THESE DO NOT INCLUDE A SID CHIP, SIDs must be user supplied !!! SIDs are easily inserted on the rear of the module. Expect retail pricing on these 50 to be around 300 GBP each.
This 'early bird' release will then be followed in the future by a Thonk DIY kit release with all related material open sourced. The module was intended as DIY - it is all through hole and built from readily available parts. Pricing on this will be decided nearer the time.
EDIT:
Draft manual: http://busycircuits.com/docs/ALM003-manual-draft.pdf
More stuff inc soundcloud demos: http://busycircuits.com/alm003
