Beauty Case - 1 Voice
gmcerveny
Post by gmcerveny » Wed Nov 04, 2009 5:34 pm
Anyone got any trickery to cram one voice in a 32hp beauty case?
Ideally I'd like a vco, vcf, lfo, adsr, and vca...
Is it possible?
:despair:
The a111-5 is cheating.
:deadbanana:
sandyb
Post by sandyb » Wed Nov 04, 2009 5:46 pm
not too tough.
2 x plan b model 37 lfo (one as lfo, one as vco) = 8hp
1 x doepfer filter (there's quite a few at this size) = 8hp
1 x doepfer a132-2 dual vca = 8hp
1 x doepfer a140 adsr - 8hp
32hp :)
i'm sure there are other combinations that would work too.
sandy
gmcerveny
Post by gmcerveny » Wed Nov 04, 2009 5:54 pm
See... I knew you would come through. I have no knowledge of the plan b catalog.
cocco88
Post by cocco88 » Wed Nov 04, 2009 5:57 pm
2x planB elf lfo
1x planB elf adsr
1x a180 mult
1x a160
1x a161
1x a105 filter
sandyb
Post by sandyb » Wed Nov 04, 2009 6:01 pm
another option
cwejman vm-1 (oscillator,filter,vca, and 2x envelope generators) - 26hp
analogue solutions lfo-nz (lfo and noise source) - 6hp
32hp total
anselmi
Post by anselmi » Wed Nov 04, 2009 6:07 pm
cocco88 wrote: 1x planB elf adsr
according with some guys here this are discontinued due to BIG design faults
richard
bananaphile
Post by richard » Wed Nov 04, 2009 6:19 pm
not that its unusual for Plan B , but what design faults are you refering to?
the M37s i have both sound great but both are very "dirty"= easily upset by and easily upsetting others VOCs and LFOs in the rack. is that what you mean?
R
REwire
Post by REwire » Wed Nov 04, 2009 6:35 pm
My recommendation:
Analogue Solutions VCO 6hp
Any 8hp Filter
A-132 Dual VCA - 4 HP
MFB Dual ADSR -12 Hp
Or if you'd rather an LFO over a dual ADSR: an A140 ADSR with the Plan-B ELF LFO - 12 hp together.
My setup leaves 2 HP open but there are no 8hp VCO's at the moment and I wouldn't trust 2 ELF LFO's unless you are not wanting a stable pitched system. They are very hard to tune. ELF ADSR's are not available and I think two ADSR's are important - one for the filter and one for the VCA.
Dan
anselmi
Post by anselmi » Wed Nov 04, 2009 6:56 pm
sandyb wrote:not too tough.
same list but changing the doepfer filter for the tiptop z2040
and maybe you can use the doepfer A-132-1 as a double VCA...the manual said that is intended for CV but it could be used with audio in non-critical aplications...that´s half the size of the A-132-2 so you can use the extra 4 HP for something else...maybe the doepfer dual ringmodulator or another M37
anyway you can´t go too far without some multiples and attenuators too...
anselmi
Post by anselmi » Wed Nov 04, 2009 7:01 pm
richard wrote:not that its unusual for Plan B , but what design faults are you refering to?
R
this thread
viewtopic.php?t=8504&highlight=expander
jonkull
Lowest Common Denominator Patcher
Post by jonkull » Wed Nov 04, 2009 7:01 pm
R
He was referring to the M38 ADSR not the M37 LFO. There was a problem with the pots on the Elf ADSRs and they are currently unavailable and have been for about a year now.
If only someone would invent a synth that would allow the end user to determine the functionality. You could pick which functions were important to you in 'modules'. A 'modular', if you will. - Stretta
wetterberg
Post by wetterberg » Wed Nov 04, 2009 7:10 pm
Hertz Donut
TipTopAudio z2040
Asol LFO-NZ.
What you get in 31HP
Two insane oscillators
Filter
VCA
LFO
Noise source.
- can't fucking beat that :-D
dougcl
Number 6
Post by dougcl » Wed Nov 04, 2009 7:17 pm
Just a thought, you might consider the A-170 at 8HP a compact dual EG.
ersatzplanet
Synthwerks Design
Post by ersatzplanet » Wed Nov 04, 2009 7:24 pm
a-111-5 synthesizer voice -24HP leaves you 8HP for another filter or 190-2 Midi, or a A-136 Distortion / Waveshaper or other wave mangler to fatten it up a bit. Or just a second VCO and you have a standard voice.
-James
jjclark
Professor Wiggler
Post by jjclark » Wed Nov 04, 2009 9:13 pm
A real challenge is to get one voice AND include a midi-cv module so that the beauty is standalone. Analog Solutions has a bunch of 6HP modules, including:
MCV - midi-cv 6HP
VCO - 6 HP
EG - ASR envelope - 6HP
LFO-NZ - lfo and noise - 6HP
then use your favorite 8HP filter from wherever - total 32HP
I haven't used the Analog Solutions modules so I don't know how good they are.
MrTea
Reptilian Brain
Post by MrTea » Thu Nov 05, 2009 4:04 am
If we're talking the Doepfer 32HP case, doesn't it only have enough power for 4 modules?
sandyb
Post by sandyb » Thu Nov 05, 2009 4:41 am
MrTea wrote:If we're talking the Doepfer 32HP case, doesn't it only have enough power for 4 modules?
afaik yes. but it would be pretty easy to make up some suitable power cables to overcome this.
mateo
Post by mateo » Thu Nov 05, 2009 10:13 am
there are 4 connectors, and a 200mA power supply...
baboo
Post by baboo » Thu Nov 05, 2009 4:12 pm
I think analogue solutions are also releasing their low pass filter in 6HP with a VCA (!) shortly- a least that's what their website says.
you could get a 6HP VCO from ASol, LFO-NZ (also 6 HP), a 6 HP filter with vca, and this leaves 14 HP for any fat module containing an envelope and perhaps something else:) the VCO and LFo-NZ work and sound very well
baboo
Post by baboo » Thu Nov 05, 2009 4:13 pm
not to mention these modules are nicely priced
gmcerveny
Post by gmcerveny » Thu Nov 05, 2009 5:33 pm
I think the 4 adapters on a 32hp beauty is defining...
That means if vco, vcf, lfo, adsr, and vca are desired, one of these needs to be combined a module.
The most logical I combo is probably vcf/vca or lpg combo (tiptop/doepfer a-101-2).
Thanks for all the input!
It's hard to beat the a111-5...
ersatzplanet
Synthwerks Design
Post by ersatzplanet » Thu Nov 05, 2009 9:04 pm
gmcerveny wrote: It's hard to beat the a111-5...
The only thing that bugs me about it is that it only has one VCO, but with the extra 8-hp that could be fixed. It is too bad Doepfer's wave multipliers are too wide. The narrow, simple MIDI interface module A-190-2 leaves you with 2HP - too small for anything but a A-198 Trautonium Manual / Ribbon Controller would fit nicely!
-James
wetterberg
Post by wetterberg » Fri Nov 06, 2009 3:11 am
but buying the 111-5 AND a midi interface doesn't make a lot of sense, does it? I mean, why not just get the Dark Energy instead then?
dougcl
Number 6
Post by dougcl » Fri Nov 06, 2009 10:29 am
How about two voices? :)
anselmi
Post by anselmi » Fri Nov 06, 2009 12:15 pm
since the z2040 got a VCA that could be configured as pre or post filter you can reduce a lot the audio path
some voice systems, the last with MIDI/CV and just 30 HP:
another cool combo could be a cwejman VM-1 and M37 ELF LFO...the VM-1 lacks an LFO but got a continous morphable multimode filter and 2 of the snappy cwejman envelopes...also audio input mergeable with the onboard oscillator so the M37 could act as a second oscillator too
or sacrify the LFO and add the doepfer MIDI/CV, but having sync and PWM input you probaly would miss the LFO...sadly non of the VM-1 envelopes can export their CV...
