Fonitronik MH01
News & Discussion
Moderators: Kent, fonik
nofuture
Fonitronik MH01
Post by nofuture » Fri Oct 18, 2013 10:56 am
Hello,
I have some questions about the MH01,
Is the AC / DC switch only for the SUM output ?
I ask this because I want to know if I can use:
3 channel to Attenuate / Invert CV while I'm using the last channel as an Audio Attenuator to set the output level of a VCO to a line level to plug it into my soundcard.
I read this in the manual:
Therefore, it cannot give you 100% unity gain. For this reason, it is not recommended for use with 1V/oct keyboard voltages.
What does this mean exactly, I don't understand correctly, if you can explain with other words it would be very hepfull. ( What I understand is that you can't have a perfect precision for note processing... (I'm not english :hmm: )) ?
Thanks.
fonik
Re: Fonitronik MH01
Post by fonik » Fri Oct 18, 2013 4:41 pm
nofuture wrote:Hello,
1st of all, your goal could be achieved.
the mode switch AC / DC acts on the sum output only.
the channels themselfes are DC coupled.
so in AC mode any DC offset gets removed from the sum.
anyways, let me tell you this: you don't neccessarily need AC coupled mixers/attenuverts to process audio. in fact all passive attenuators are DC coupled.
why do you want to use an AC coupled attenuator for your audio? is there an DC offset in your audio? if so then you could still use the mh01 as intended:
use channels 1 to 3 as attenuverters, but remove them from the sum by using the single outputs (a patch cord in the single outputs removes the corresponding channel from the sum).
then only channel 4 is fed to the sum and now you could even remove any DC offset by using the AC switch.
8_)
you got it 100% correct: no precision for note voltage processing.
nonetheless you could use it for note CV. i do it all the time. i feed the channels with gatesignals from a divider and attenuate them to the correct pitch i need. makes a nice little sequencer, something like this:
binary game sequencer (fonitronik DIY)
Big Boss at fonitronik.de
Tech Buddy at Random*Source/Serge
nofuture
Post by nofuture » Sun Oct 20, 2013 12:05 pm
Okay, nice !
Thank you very much for your answer !
Kosel
Post by Kosel » Tue Jun 17, 2014 3:43 pm
I've got my own, and i'm hugely please of that.
Very good quality of knobs, switches and potentiometeres.
I guess that some poeples would says 12HP for Attenuator is too much and it is waste of space.
Regardless, highly recommended.
Cheers!
fonik
Post by fonik » Wed Jun 18, 2014 10:57 am
:party:
thanks for the kind feedback!
Return to “fonitronik”
