gate delay with VC gate length?
A Dingleberry Monstrosity
eat the kids first
Post by A Dingleberry Monstrosity » Fri Nov 06, 2009 3:34 am
I only know of 2 gate delay, doepfer and AS. Both are cool but seem to be not super dynamic.
I know plan B has one on paper... but.... yeah...........
Does anyone know of any others? One with VC gate length?
We make guitar pedals: whimsymachines.com :party:
SynthBaron
Post by SynthBaron » Fri Nov 06, 2009 3:59 am
A-141 VCADSR.
I assume you want to delay a short "trigger" length gate?
Gate you want to delay to gate in
Attack would control delay time.
Decay would control gate length. This is where you'd want to VC it.
Sustain set to 0
Release set to 0
Envelope out to where ever you want the delayed "gate" to go. This works because gate inputs won't trigger unless a signal meets a certain voltage threshold.
MATHS and other VC-AD/R type modules would most certainly work too.
Multi-use modules. :mrgreen:
wetterberg
Post by wetterberg » Fri Nov 06, 2009 4:10 am
yeah, the maths has an EOR pulse out on one channel (strangely, that R is not "Release", but "Rise") and an "End of Cycle" EOC on the other. But they're pulses, not gates.
The a-142 could do it, or there abouts. It has a variable comparator built in, and an inverse out. Okay, not quite there, but close.
SynthBaron
Post by SynthBaron » Fri Nov 06, 2009 10:27 am
wetterberg wrote:yeah, the maths has an EOR pulse out on one channel (strangely, that R is not "Release", but "Rise") and an "End of Cycle" EOC on the other. But they're pulses, not gates.
OK, but I'm talking about using the actual output of the AR to use to gate other modules.
You could use it in conjunction with a slew limiter or trigger delay to get the wanted effect.
