help with VCNoiz
Discussion for Hexinverter eurorack modules - email Hex if you need anything urgent!
Moderators: Kent, infradead, hexinverter
Sony Crocket
help with VCNoiz
Post by Sony Crocket » Sat Oct 19, 2013 7:27 am
Hi!
I finished building the vcnoiz but I get no sound on it. IC6 (TL074) gets hot.
I replaced it with a new one, but no results.
Checked all resistors and caps.
Help please!!
Thanks.
hexinverter
the nettles make me think happy times
Re: help with VCNoiz
Post by hexinverter » Sat Oct 19, 2013 7:43 am
Sony Crocket wrote:Hi!
Help please!!
Thanks.
Hiya!
Sounds like you have a short somewhere or a reversed IC installed. The TL074 getting hot is most likely a product of the problem and is probably not the cause of it, so, I would inspect elsewhere on the PCB for issues. Look for reversed IC sockets, reversed power connections or anything else amiss.
Here's my basic troubleshooting page with some tips. Good luck!
http://cv.hexinverter.net/?projects=diy ... leshooting
Hexinverter Électronique
em: stacy[at]hexinverter.net
Sony Crocket
Post by Sony Crocket » Sat Oct 19, 2013 10:47 am
Got it!!
It works flawlessly now!
I can now start with the neinohnein build. Really nice modules.
Thanks for your support.
analogdata
Post by analogdata » Sun Oct 20, 2013 11:18 am
Sony Crocket wrote:Got it!!
curious.
what was the problem?
my vcnoiz is also dead.
maxime.annah
Post by maxime.annah » Thu Mar 05, 2015 10:42 am
curious.
also curious, mine is also dead (no sound at all), and I've also got IC6/TL074 who's getting hot !!! Can't find any shortcuts but I saw with a tester that the pin 3 & 5 are connected, is it normal?
and I bet it's normal that R3 is connected to pin6 (they are so close)?
thanks
hexinverter
Post by hexinverter » Thu Mar 05, 2015 12:57 pm
A common problem is to miss the fact that you need to normalize the clock output to the input via a switching jack, or switch, or whatever :)
Besides that, it's a fairly simple build so as long as you wired the jacks and controls carefully, you should have some audible LFSR noise when you turn the pitch control up!
There's probably a bridged or missed solder joint somewhere, or a backwards IC...it's easy to do, I make mistakes like that more than I care to admit :hihi:
maxime.annah
Post by maxime.annah » Thu Mar 05, 2015 2:56 pm
:doh: it was just the clock out to clock in connection :doh:
I'm with banana so no switching connector so ... no connection ... I will put a banana strap if I can find some ...
thanks a lot :yay: and it sound AMAZING !!! :yay:
Return to “Hexinverter Electronique”
