[IN STOCK] E.A.S. "miss 10" LFO/Noise/S&H v2.0
Randy
Post by Randy » Mon Jun 30, 2014 8:30 pm
Great news! Any chance of some sort of build doc? Or is it idiot-proof?
Randy
E.A.S.
Post by E.A.S. » Mon Jun 30, 2014 8:53 pm
Randy wrote:Great news! Any chance of some sort of build doc? Or is it idiot-proof?
Randy
Pretty Idiot proof. That said, I'll put one together just in case.
-M
E.A.S Miss ten series PCBs-----
MISS 10/20/50 VCO,
MISS 10/20 VCF/A,
MISS 10/20 LFO/NOISE/S&H,
MISS 20 MINDREADER PCB/POTs.
Randy
Post by Randy » Mon Jun 30, 2014 10:34 pm
That's good, thanks. I can be a kinda special idiot.
Randy
blandoon
Post by blandoon » Thu Jul 03, 2014 3:01 pm
Cool, great news.
I don't know if anyone is building this in a non-Euro format, but since I have to add a MOTM-style power header anyway, I was gonna try to build a little piggyback board with female 0.1" and male MTA156. Then I can also include a gate-to-trigger converter, and add a panel switch to choose "track-and-hold" or "sample-and-hold."
We'll see if I am not too dumb to actually make it work :deadbanana:
E.A.S.
Post by E.A.S. » Fri Jul 04, 2014 3:03 pm
blandoon wrote:Cool, great news.
Another fun mod to do it with another switch, to switch the s/h cap in/out of circuit. the circuit then becomes a VC switch, audio passes when gate is high, doesnt when gate is low. (it'll do this as is, but when the gate goes low, the cap holds it at the last voltage) just an idea.
-M
MISS 10/20/50 VCO,
MISS 10/20 VCF/A,
blandoon
Post by blandoon » Sun Jul 06, 2014 2:30 pm
E.A.S. wrote:Another fun mod to do it with another switch, to switch the s/h cap in/out of circuit. the circuit then becomes a VC switch, audio passes when gate is high, doesnt when gate is low. (it'll do this as is, but when the gate goes low, the cap holds it at the last voltage) just an idea.
That there's an interesting idea... so switch between having the cap in place and shorting across it? I might do that too if I have the panel real estate - I really want to fit this in one Frac unit (about 8 HP).
E.A.S.
Post by E.A.S. » Sun Jul 06, 2014 3:38 pm
The switch would just essentially "lift" one of the cap legs, not short across it. you might want to try this mod out before committing it to a panel, as im not exactly sure how much the switch and wiring would affect the droop of the "Hold" function.
MISS 10/20/50 VCO,
MISS 10/20 VCF/A,
blandoon
Post by blandoon » Sat Jul 12, 2014 7:34 pm
Preliminary crappy Frac panel design, including sample/track switch:
E.A.S.
Post by E.A.S. » Sun Jul 13, 2014 7:32 pm
blandoon wrote:Preliminary crappy Frac panel design, including sample/track switch:
I like it! :tu:
MISS 10/20/50 VCO,
MISS 10/20 VCF/A,
woodster
Post by woodster » Mon Feb 02, 2015 5:43 am
Necro thread bump.
Does anybody have a BOM for this V2 LFO ?
It looks very different to the V1 BOM, and there are no component values on the PCB (see Mike's post above).
I'm sure Randy posted this question during the recent chaos period for Muff's, but the thread has completely vanished.
I've held off building this because of no BOM and no panel, but I've got the bits to make a bracket and panel, and hate the thing just sitting there doing nothing, especially when I need more S&H and Pink Noise...
E.A.S.
Post by E.A.S. » Mon Feb 02, 2015 8:48 am
woodster wrote:Necro thread bump.
Re-doing a BOM for this right now. My old computer 'crashed' (5 years old kids tend to help with the process) I will be posting a BOM for this within the next couple days.
:tu:
-Mike
MISS 10/20/50 VCO,
MISS 10/20 VCF/A,
woodster
Post by woodster » Thu Feb 12, 2015 6:32 am
I'm looking forward to being able to get going with this build.
Many thanks for the pending BOM :tu:
E.A.S.
Post by E.A.S. » Thu Feb 12, 2015 11:17 am
woodster wrote:I'm looking forward to being able to get going with this build.
Here we go!! w/ mouser part numbers.
let me know if anything looks weird!
-Mike
C1.....10uf/16v................647-USA1C100MDD
C2.....1uf/50v..................647-UMA1H010MDD
C3.....47p........................505-FKP247/1000/10
C4.....10uf/16v.................647-USA1C100MDD
C5.....0.022uf...................505-MKP2G022201E00MS
C6.....0.1 uf.....................505-MKS2.1/63/10
C7.....1uf np.....................505-MKS2C041001FKI00
C8.....0.1 uf......................505-MKS2.1/63/10
C9.....0.1 uf........................505-MKS2.1/63/10
C10.....10uf/16v.................647-USA1C100MDD
C11.....10uf/16v.................647-USA1C100MDD
D1.....1N4148................583-1N4148-T
D2.....1N4148................583-1N4148-T
D3.....1N4148...............583-1N4148-T
D4.....LED......................604-WP7113ID5V
D5.....1N4148..............583-1N4148-T
D6.....1N4148...............583-1N4148-T
D7.....1N4148..............583-1N4148-T
IC1.....LM4558...............595-RC4558P
IC2.....LM4558................595-RC4558P
IC3.....TL071....................595-TL071CP
IC4.....LM4558................595-RC4558P
Q1.....2N3904............512-2N3904TF
Q2.....2N3904..............512-2N3904TF
Q3.....J111......................512-J111D26Z
for resistors use mouser part
# 271-xxx-RC , where "xxx" is value listed below.
R1.....100K
R2.....1M
R3.....2.2M
R4.....10K
R5.....1K
R6.....6.8K
R7.....220K
R8.....1K
R9.....100k
R10.....10k
R11.....470
R12.....220k
R13.....100k
R14.....10k
R15.....10k
R16.....1k
R17.....1M
R18.....1k
R19.....1k
R20.....3.3K
R21.....20K
R22.....1K
R23.....100K
R24.....4.7K
R25.....4.3K
R26.....2.7K
R27.....4.7K
VR1.....100K TRIM.....858-64WR100KLF
VR2.....10k TRIM.....858-64WR10KLF
VR3.....100KB.....313-1000F-100K
VR4.....10KB.....313-1000F-10K
MISS 10/20/50 VCO,
MISS 10/20 VCF/A,
woodster
Post by woodster » Thu Feb 12, 2015 12:25 pm
Many thanks indeed Mike.
Very much appreciated.
lamouette/rck
Post by lamouette/rck » Thu Feb 12, 2015 1:00 pm
i would like to get one PCB/Panel set, is it possible ?
Setup is never done.
woodster
Post by woodster » Thu Feb 12, 2015 1:37 pm
PCB's were available via Mike, but Panels were a separate matter.
I'd love to get some proper panels for the Miss10 PCB's, but I'm going to attempt some ghetto homebrew ones...
Randy
Post by Randy » Tue Mar 03, 2015 12:29 pm
Does anyone have a photo of a finished V2.0 LFO PCB?
Randy
Randy
Post by Randy » Tue Mar 03, 2015 7:49 pm
I'm also having trouble finding the LM4558. Will these do?
http://www.ebay.com/itm/dual-opamp-8p-5 ... 0662684218
I have a bunch of TL072, can I use those instead?
Randy
woodster
Post by woodster » Tue Mar 10, 2015 6:49 pm
Hey Randy,
Mike gives a Mouser reference for the RC4558P as a suitable part in the BOM.
I presume it's correct, I hope so, as I have 3 on order for this module :hihi:
http://uk.mouser.com/Search/ProductDeta ... 95-RC4558P
As requested, I've attached a picture of my build, showing where I am currently with the PCB, and the component stuffing.
I'm now just waiting on the Trimmers (VR1 & VR2), a J111 (Q3) and a 47pf Wima Cap (C3) -
Let me know if there's anything else I can help you with.
I'm always happy to try to help a fellow wiggler get a build successfully completed.
Randy
Post by Randy » Tue Mar 10, 2015 9:17 pm
Thanks woodster. I hate to order three little ICs from Mouser, the delivery charge will be a bit nuts. Those are the only things I think I still need. I've been using a heavy-duty aluminum cookie sheet as a source of panel material, so making a panel is up next.
Randy
woodster
Post by woodster » Wed Mar 11, 2015 7:24 am
Cookie Panel FTW
Randy
Post by Randy » Mon Apr 27, 2015 4:31 pm
Does anyone have a wiring diagram for this? I also need the pot values, and I'd like to know what the trimpots are for?
Did I miss something here?
Randy
woodster
Post by woodster » Tue Apr 28, 2015 7:38 am
Hey Randy,
Pot Values are there in the BOM above, 100k for VR3 and 10k for VR4.
One of them is LFO Speed, the other is a Waveform Skew, which is which ?
I don't yet know, but thought it would be obvious enough once I get a panel made and get it all wired up.
Trimmers, I'm not 100% sure about the functions, but was going to suck it and see when the time came, maybe there is mention in the old V1 thread ?
For a wiring diagram, I plan to go off the old V1 sketch, as I imagine it's mostly the same, even though the V2 circuit is slightly different to the V1
Randy
Post by Randy » Tue Apr 28, 2015 8:25 am
I'm looking at the panel on ModularGrid, which also has pots for white and pink noise and S&H in. I could do without the attenuators for the noise and I'm not even sure why there would be a pot for S&H in. I'm also not sure where to hook up the Fast/Slow switch.
I suppose I could just do the two controls and get it over with but Mike put together a really handy diagram for the v2.0 VCF here and having something like that for the LFO would be great.
Randy
Dimitree
Post by Dimitree » Tue Apr 28, 2015 9:22 am
how do you switch (circuit-wise) from track&hold to sample&hold?
