Multiples!
mateo
Multiples!
Post by mateo » Sun Nov 08, 2009 11:47 am
As I'm putting together my first system, I've started wondering what to do about multiples:
1) Grab a couple of a-180s and sticking them in the case? Easiest option, but not HP efficient. How many would I need for 9U anyway?
2) Stick some a-180s in a small external case (like that IKEA picture frame)?
3) Grab one of those Ad Infinitum racks? But it has an open back, so I would need so kind of enclosure for that.
4) Grab a couple of BAMs and put them in the case instead? How many of those?
5) Something else entirely?
:despair:
wetterberg
Post by wetterberg » Sun Nov 08, 2009 12:03 pm
1) If you're going to fret over 4HP you might as well get another case straight away. I get by with a single mult for 12U, but could do with another.
2) Sure. See 1)
3) That's a good use of an extra 1U in your rack - no need for enclosure though.
4) What makes that different from 1)?
5) Yes, diy. Drill a ton of holes in a cigar box, put in minijacks and wire everything up together.
dbuyense
Post by dbuyense » Sun Nov 08, 2009 12:52 pm
I think the Tiptop banana style cables are going to be a great alternative.
4) I think the .bam's are more important for note cv's to a bunch of oscillators , attenuation loss for other modulation cv's like lfo's don't seem to be too much of a problem. I'm currently splitting a note cv signal through a non buffered normal multiple to two oscillators and I'm not really having tracking problems but its been suggested to use a buffered multiple when controlling multiple oscillators.
daverj
Vintage Video Wiggler
Post by daverj » Sun Nov 08, 2009 1:32 pm
If you have one of the Doepfer portable cases, some people have cut holes in the wood strips at the top and bottom to mount multiples in.
loudone
Post by loudone » Sun Nov 08, 2009 3:01 pm
the new modular world road cases come with 6x4 multiple on bottom
ST UF FLI N EAR
Post by ST UF FLI N EAR » Sun Nov 08, 2009 3:11 pm
1) you're sticking them in the case... which case?
when its a diy, i would add an aluminum strip over the whole width. ( like on the MW)
dougcl
Number 6
Post by dougcl » Sun Nov 08, 2009 3:28 pm
One M31 is about right for 9U.
ersatzplanet
Synthwerks Design
Post by ersatzplanet » Sun Nov 08, 2009 4:16 pm
I have a few multiples in my rig. I started with the simple Doepfer A-180 which I modified to normal the 2 4-way mults to be a 7way if the 5th jack isn't used) but no have bought a couple of A-182 which I find are much nicer to use in a live or experimenting environment. The switched busses adds allot of flexibility at the expense of just 2HP.
http://www.analoguehaven.com/doepfer/a182/
-James
mateo
Post by mateo » Sun Nov 08, 2009 5:38 pm
Thanks for all the responses! I'm planning on a Monorocket Mission 9, so that limits my options. I'm not terribly worried about HP, I've just gotten the impression from a number of posts here that it's a waste of space to use up HP for passive modules.
My comment regarding an enclosure for #3 is because I want things to be (relatively) portable, and I wouldn't want to have to lug a rack around *just* for the multiples. In the studio it'd be fine though.
As for the BAMS, they're interesting not only because they're buffered, but because they also acts as attenuators/amplifiers. Considering I'm planning on having quite a few oscillators, I think having at least one of them would be essential; combined with the tiptop cables I think my needs would be covered.
The model 31 looks great, but I'm going to steer clear of plan b for the moment....
