stands for doepfer 6u suitcases ?
doepferiano
Post by doepferiano » Wed Nov 11, 2009 9:53 am
Hello wigglers,
what is the best way to have 2 suitcases one on top of the other, in a slanted way (a la Buchla...) ?
:hmm:
thanks
antonio
Cat-A-Tonic
Lobsters love Muff
Post by Cat-A-Tonic » Wed Nov 11, 2009 10:09 am
Maybe you could use a guitar stand for the more vertically angled 'top' one,
and put the other 'horizontal' one in front on its back
(propped up with something random in back if you want more angle).
RetBody
Post by RetBody » Wed Nov 11, 2009 11:09 am
Do you want something tabletop or floorstanding?
For floorstanding, how about this: http://www.sweetwater.com/store/detail/Autolocator/
It does a great job holding 1 doepfer case, and can handle enough weight that I usually have it supporting heavy Otari reel-to-reel. You'd probably have to improvise a back support to deal with the extra height of a 2nd case, but it can definitely handle with width and weight. (or you could just get two stands, and set one taller and steeper behind the other.)
hbc
III IV III
Post by hbc » Wed Nov 11, 2009 11:17 am
Cut down A-frame stands work well. You've got to modify the brackets a little bit.
Here's a thread with a picture.
doepferiano
Post by doepferiano » Wed Nov 11, 2009 11:40 am
I'd like more a table top situation
yes this is closer to what I have in mind
I know the the easiest would be a table top "L" configuration ...
(maximizing teh use of cable lenght too!)
ersatzplanet
Synthwerks Design
Post by ersatzplanet » Wed Nov 11, 2009 2:27 pm
The type of Guitar stands that don't use a neck holder work great as table top stands for the Doepfer portable cases. And they are tpically around $20 and go on sale often. They look like this:
http://www.zzounds.com/item--MUPGS7462B
http://www.activemusician.com/item--MC.6042
Those work great for tables but if you need some for free standing a cheaper alternative than the mixer stand shown earlier are guitar amp stands like this:
http://www.musiciansfriend.com/navigati ... G&ZYXSEM=0
The $14 one on that page would work on a table too but check the widths first. Most of them are for amps wider than the ~18" of the Doepfer cases.
-James
-James
Audio Resistance
despair extraordinaire
Post by Audio Resistance » Wed Nov 11, 2009 9:48 pm
RetBody wrote:Do you want something tabletop or floorstanding?
Will that go almost totally vertical?
Will it lower enough to use sitting in a chair?
That might be perfect for a Serge S-Case.
Audio resistance to perceived fascist tendencies
My Music
