Splicer... (new mini-project)
MUFF WIGGLER Forum Index -> Music Tech DIY Goto page 1, 2, 3, 4, 5  Next [all]
Author Splicer... (new mini-project)
J3RK
Edit:
Original Message:
I was thinking about doing a wave splicing sort of thing ala Plan B today. Not sure how Peter did it, so I whipped up my own. (which is probably pretty similar I would imagine)
It's basically two precision half-wave rectifiers (diodes flipped on one) going into a mixer. The rectifiers are inverting, so the phases swap places, and then the mixer (also being inverting) swaps them back to their original phases.
I'm going to whip up a small board for this, and maybe add a feature or three. It's a fairly simple design, made up of common components, so I'm happy to post the schematic once I lay it out as well. Right now I just have it sketched out on paper.
More soon!
w00t
FetidEye
cool! i think i'm ready to build from schematic (if simple enough)
what do you mean by precision rectifiers?
J3RK
This one should be absolutely no problem for you. One chip, a few resistors, and a few diodes.
By precision, I just me op-amp based rectifiers. (otherwise the waves could come out a little odd...) Nothing terribly special about them. That's just how I've seen them referred to while researching how I might do this.
J3RK
I had a few minutes between a couple of projects tonight, so...
w00t
There's an unused op amp left on the TL074, so this could be used to make an inverted output. Pots could be swapped in on the feedback resistors for gain adjustment as well if desired.
J3RK
Might as well use that last op amp. This is fun!
vurma
This looks quite useful! Keep us updated on that board will ya? ^^
J3RK
Your updated is ready This is fun! Now it's just a matter of seeing if someone wants to stock them. If there's only a small amount of interest, I could do a small run, but I don't have enough time to do a big one right now with all of the shipping etc.
It's ready to place an order though once I have an idea of how to approach it. It will be a very inexpensive board. Could also be fun with a pair of VCAs maybe to have voltage control over the inputs. Not sure what that would look like, but I may try it out.
More as soon as I figure out what to do with it.
microfauna
Is this 12v or 15v? Could you put a Euro power header footprint on?
KNYST
Neat! Yes please w00t
CV input?
vurma
Awesome!
Looking at the PCB, it seems like its already taken care of.
BugBrand
It shouldn't matter 12V/15V -- it is just opamps doing their thing..
CV input? Perhaps simply adding further waves to the input summing nodes - ie. add further resistors like R3 and R4
That extra opamp could, perhaps, be used for CV/Modulation input? Haven't tried, but could it be interesting to have one Mod input going to both input sides, but have one inverted (ie. through that spare opamp) - should be easy to try on your software.
microfauna
vurma wrote:
Awesome!
I see the header shape, but not the solder points.
KNYST
I have a M39. I'd say the VC input on it is essential. Morphing, fading between the input waves...
When nothing is plugged in into the VC input, one can use the pot to sweep between the two input signals.
For anyone interested, read more here: http://www.modulargrid.net/e/plan-b-model-39
catchpenny
does this work with CV signals?
BugBrand
CV/DC - yes (well, presumably..)
Knyst - I think.. that my suggestion for the final 1/4 opamp with one CV input going inverted & non-inverted could well do that cross-fading. It makes sense in my head, at least.. Oh - or maybe you DON't want to invert the CV. Hmm. Simulation needed!
KNYST
ah, yes, thanks.
Will be following this with interest.
BugBrand
AHHH!
Did a quick sim (I'm not very good with such things actually)
You just need to add the CV (non-inverted) to BOTH nodes
but then ALSO into the summing node after the half-wave-rectifiers.
Oooh!
BugBrand
OK - wow, so that's kind of like a cross-fader...
Here I have a 10Hz and 50Hz sine going in
0.1Hz sine for modulation.
KNYST
vurma
BugBrand wrote:
AHHH!
Oooh!
Haha! Sounds like some good hacking is going on over there. What software are you using for the simulation?
BugBrand
LTSpice - free!
http://www.linear.com/designtools/software/
Only been learning it quite recently..
BugBrand
Wow (again)
The idea works in the nord g2 demo software too!
J3RK
It will run on either with no changes. Also, yes, a Euro header would be quite easy to add, and I'll definitely add it.
J3RK
BugBrand wrote:
AHHH!
Oooh!
Nice! That's very cool! I was going to suggest that I add a VCA in front of each input, (which could still happen,) but your way is much smaller! Thanks for looking at this. 8_) thumbs up applause
oberkorn
interested! I'm in for two
Page 1 of 5
