Splicer... (new mini-project)
snaper
Post by snaper » Thu Jul 14, 2016 1:53 pm
Has somebody the schemo?
The picture on the first page is down :(
synthcube
you will be assimilated
Post by synthcube » Thu Jul 14, 2016 2:06 pm
here's the schematic
snaper
Post by snaper » Fri Jul 15, 2016 1:50 am
synthcube wrote:here's the schematic
Thank you very much!!!
snaper
Post by snaper » Thu Jul 21, 2016 2:31 pm
Last question, at some point I've lost in this thread.
So, is this OK for CVs?
Buchla implementation, so I have to know that should I put jacks or bananas to the wave inputs :D
locobitch
Post by locobitch » Tue Apr 30, 2019 10:59 am
I just discovered the only module able to do this function and it was the Model 39 :/ Now i'm in search for this module but in eurorack.
J3RK do you have some kits for sale in eurorack ?
synthcube
Post by synthcube » Tue Apr 30, 2019 11:41 am
we offer the PCBs here, and have plans for a euro version...
locobitch
Post by locobitch » Sat May 11, 2019 4:41 am
Some more questions.
It's possible to add some fade knob like on the model 39 ?
If yes anyone has a bom for the eurorack version ?
Ayab
Post by Ayab » Sat May 11, 2019 10:42 am
Hi locobitch
The bom from the schematic supplied a few posts up from Synthcube -
Resistors: 6 x 100k, 6 x 49.9k, 2 x 330ohm
IC: 1 x TL074 op amp
3 x Diodes (1N4148?)
6 x jack sockets - Type of jacks should not matter if there is no panel pcb.
Not shown: Power header socket, couple of beads or resistors and 2 x 10uf (or choice) electrolytic capacitors on power input and couple of 100n ceramic capacitors to decouple the ic.
locobitch
Post by locobitch » Sat May 11, 2019 4:30 pm
Cool thanks Ayab :D Do you know if it's possible toi implement a turn knob like on the model 39 in parallel of the CV input ?
Ayab
Post by Ayab » Sun May 12, 2019 5:25 pm
A switched jack for the CV input with the switch connection normalled to +15V via a 100K resistor and the tip of the jack going to one outer connection of the pot, the other outer connection of the pot going to ground and the wiper of the pot going to the R11. 100K pot.
Then if the CV connection is not used the pot is a voltage divider and sends a voltage depending on the pot position and if a CV is connected the pot acts as an attenuator.
The attached picture makes this clearer.
Hope someone can please confirm that I am correct about this.
soup
Post by soup » Sun May 12, 2019 9:25 pm
The fader on mine wants wants +5V to -5V.
You could make 2 voltage sources and a dc mixer on a bit of stripboard but you'd double the size of the pcb.
Ayab
Post by Ayab » Mon May 13, 2019 9:06 am
Aah ok I see :oops: thank you for pointing that out, soup.
I think your suggestion for a small dc mixer on stripboard is a good one.
locobitch
Post by locobitch » Wed May 15, 2019 9:45 am
The idea is to have a pot to manually change the slice point and not having to use uniquely the cv in for that.
soup
Post by soup » Wed May 15, 2019 11:27 am
The splice point can't be changed. The CV in (whether you add a knob or not) fades between the negative and positive sides of the waveform.
