14hp to fill advice-wogglebug or noisering
dbuyense
Post by dbuyense » Mon Nov 16, 2009 1:47 am
I was thinking of getting a 2nd wogglebug , but am considering a noisering. any opinions . My impression of the noisering is I don't care for the samples I've heard from it used as a audio source , don't need another noise source , I do like samples I've heard of it processing audio , I think I would use it alot as a modulation source. I've heard the noisering and wogglebug compliment each other. What do you all do with your noiserings the most in patches audio source/processing signals/or for modulating.
So whats some opinions a 2nd wogglebug , a noisering or maybe even a plan b asr leaving 10hp open for something else.
suboptimal
A Towering Mediocrity
Post by suboptimal » Mon Nov 16, 2009 2:17 am
The last few days I've been working up a patch with the Noise Ring at the center. As a direct semi-chaotic source of cv/oct it's incredible fun, but when you mult it to a few sources it quickly gets fantastic. I've got a patch in the works now using its noise source for a snare, and its clock output as the master clock of a complex LFO mishmash. It's struck me as reaching straight into the core of the classic Subotnick recordings (with the Maths playing a huge part).
Not sure how it would be used "processing audio"? It's a modulation source at the core. I'd like to get what I'm working on up as a demo soon.
dbuyense
Post by dbuyense » Mon Nov 16, 2009 2:47 am
suboptimal wrote: Not sure how it would be used "processing audio"?
"processing audio" wasn't a good way for me to say it.
Quoting the wiard site "Processing External Data" through the chance input.
jenamu6
Post by jenamu6 » Mon Nov 16, 2009 3:50 am
I don't have my wogglebug (built) yet.
But my noisering is really usefull for:
-creating semi random musical phrases
-Nice oscillator
-Noisesource
-Clock source
-Interesting blinky blink
One of my favourite modules.
Yohda
Post by Yohda » Mon Nov 16, 2009 3:53 am
For me it's a modulation source, waveform processor and digital oscilator/noise generator. I use it for all this applications.
If you allready have a wooglebug, I would take the noisering, very flexible and fun.
Blackened Justice
Post by Blackened Justice » Tue Nov 17, 2009 4:57 pm
Okay, I'm debating over the same thing. Just on paper, as I have no modules yet. I have an MFB Kraftzwerg, which has a S&H noise waveform on one of the LFO's and has a white noise source available.
Which of these two modules would serve me the best, at least in a smaller set up? Just to give you a general idea on my first set up, it'll include a QMMG, a Maths, some mixers, a ring modulator (if the moddemod isn't available, I'll build a dual CGS real ring mod), an A-189 bit crusher, an A-137 Wavefolder, an A-143-3 Quad LFO, an A-156 dual quantizer and the RS-35 pitch to CV. I haven't decided on a first filter, but it's between the Wasp, the Boogie and the Z2040. I'll probably add a Hertz Donut and a Zorlon Cannon afterwards.
sonicwarrior
Post by sonicwarrior » Tue Nov 17, 2009 5:26 pm
If it helps: I've just made two demos mainly with the Noisering as an audio source, modulated by a A-143-3 LFO (first one) and polarized mixture of two A-143-3 LFOs and one A-143-1 AD (second one):
http://soundcloud.com/changeling/clockw ... -assmaster
http://soundcloud.com/changeling/clockw ... ssmaster-2
Nothing fancy but I think you'll get an idea of the sound.
johnnymad
turbo wiggler
Post by johnnymad » Tue Nov 17, 2009 6:42 pm
i don't have a wogglebug, but i would have to be pretty desperate to sell my noise ring.
ex_dead_teenager
Electro-Busker
Post by ex_dead_teenager » Wed Nov 18, 2009 4:24 am
I don't have a noisering but I'd be hard pressed to sell my wogglebug. go with the noisering if you have to chose then if you want a second wogglebug down the road, get it!
Yohda
Post by Yohda » Wed Nov 18, 2009 4:49 am
Here is a quick demo I made with my Wiard modules : 2X antiosc, Noisering, Miniwave, Boogie, Borg, Wooglebug.
All the noisy/mettalic sounds comes from the noisering, the sound in the end are antiosc modulated by wooglebug and send through the chance input of the noisering.
frozenkore
Post by frozenkore » Wed Nov 18, 2009 4:41 pm
Nice demo! :tu:
Yohda
Post by Yohda » Thu Nov 19, 2009 3:07 am
Thank you!
dbuyense
Post by dbuyense » Fri Nov 20, 2009 7:37 pm
thanks for posting that demo.
I decided to reserve 14hp for a noise ring , if I feel like I need a second wogglebug after getting a noisering I'll just have to make room.
I need a miniwave I think i'm going to have to start up a row of frac I e-mailed blacet asked when and if the miniwave will be available in euro he said not anytime soon.
jonkull
Lowest Common Denominator Patcher
Post by jonkull » Fri Nov 20, 2009 7:51 pm
Yohda wrote:Here is a quick demo I made with my Wiard modules...
Nice track!
If only someone would invent a synth that would allow the end user to determine the functionality. You could pick which functions were important to you in 'modules'. A 'modular', if you will. - Stretta
Veqtor
Post by Veqtor » Fri Nov 20, 2009 8:46 pm
The noisering and the wogglebug do compliment eachother, they're based on 2 different buchla circuits which were toghether in the "source of uncertainty" module, so yes, YOU NEED BOTH!
:sb: :sb: :sb:
dbuyense wrote:I need a miniwave I think i'm going to have to start up a row of frac I e-mailed blacet asked when and if the miniwave will be available in euro he said not anytime soon.
Get the piston honda? I think it'll be like the miniwave, only 10x better!
