MS-4 questions
MUFF WIGGLER Forum Index -> Alyseum
Author MS-4 questions
rozzbud
hi,
is it a standalone midi to copperlan converter?
Can i go from a hardware 32ch midi sequencer to 2xms-4 to 2xms-812 without a computer?
And is it possible to sequential switch (like a seqsquared) the midi output without other modules?
Automate a midi ch to switch between 4 outputs on ms-812 for instance.
thanks
alyseum
Hi rozzbud
Yes the MS-4 is also a MIDI in to CopperLan converter; like the AL-22, but with a single MIDI In.
Yes, with 2 MS4 or a single AL-22 and you have 32 MIDI Ch razz
About the seqsquared, it's not the same function, it's not possible to switch differents MIDI CH to differents output in real time
Regards
rozzbud
if i understand correctly i have to use copperlan manager on pc for al-22 whereas ms-4 comes with programs per midi channel.
So ms-4 needs no computer at all?
alyseum
Yes and No, You need the computer to established they connections or programming the setting for the inputs CV.
After, for live and performance, you can use the MS-4 without computer.
Kashif
This is extremely pleasant and average post....you shook posting it....thanks a ton for posting it..!! woah woah woah
