A small window into a master plan
chocolatyshatner
Post by chocolatyshatner » Fri Mar 12, 2010 8:01 pm
4 envelators sounds about right to me . . . I've been thinking about replacing my 143-2 and 143-3 with more envelators . . . that would be insane! Loving the cycle delay!
J3RK
Post by J3RK » Sat Mar 13, 2010 1:11 am
bsmith wrote:
4 Envelators is quite a bit, but since the can be used to divide clocks or perform LFO duties, I don't think it ends up being overkill.
J3RK, thank you so much for all of the samples you've posted - they've definitely been influential on the route I've decided to take as I've started making decisions on how to proceed building my first modular rig. This thread itself has been for sure. See pic below :)
I'm new to all this and want to understand why you'd pick a noise ring to switch for the uncle osc instead of an envelator (the envelator is definitely a madman, as I'm finding out, but so is the noisering, and I'm just curious is all).
By the way, posted a small noodle from messing around with the envelator last night viewtopic.php?t=14037
Thanks! I'm glad people have been liking them. Basically, I'll start patching, and then I hit a point where I'm just having a ton of fun with the patch, and hit record for a bit. :) (except for a few small multitracked ones that I put together)
As far as those swapping choices, I'd never get rid of a second NoiseRing (once I have one again.) The only reason I'd swap it for an Uncle is that I could move it out into another rack or case (I have a few, all of which are empty, but with rails ready for modules.) I'd still have it, I'd just have to patch from another rack. I'm just looking for a little diversity within the 6U case I'm designing. (got the initial sketching part done, just need to decide on wood, and start making real measurments)
I had two NoiseRings in a Frac system I used to have, and they were the core of nearly every patch in some way or other.
I figure I need a filter and a couple VCAs, so the Boogie and two Borgs have to stay. I need clock division, LFO, and Envelopes of several Envelators, and eventually the sequential properties of the Anti-envelopes. The NoiseRing has to be in the system, can't live without one, but I can get by on the multiple outputs from a single one I think.
I wanted to build a 9U folding case, but then it's not quite as portable. I mean, it would be movable, but not something I could put on the coffee table, and muck about with.
However... (now look what you've done :mrgreen: ) an extra NoiseRing would be nice... Heh...
Nice setup too by the way. As soon as my Env and AO show up, we'll have identical sets of Walekard modules...
jonkull
Lowest Common Denominator Patcher
Post by jonkull » Sat Mar 13, 2010 1:51 am
Well looks like one of the Envelators I picked up this afternoon doesn't work. :deadbanana:
If only someone would invent a synth that would allow the end user to determine the functionality. You could pick which functions were important to you in 'modules'. A 'modular', if you will. - Stretta
revmutt
Knutty For Knobs
Post by revmutt » Sat Mar 13, 2010 9:24 am
plord wrote: Gemini for me. Couldn't keep it to 9U.
What is this Gemini you speak of?
Tommy DOG
Punk Rock Star, gambler and stunt double
sandyb
Post by sandyb » Sat Mar 13, 2010 9:44 am
this :nana:
there's a bit of discussion here:
viewtopic.php?t=14052
sandy
bsmith
Post by bsmith » Sat Mar 13, 2010 10:41 am
J3RK wrote: 4 Envelators is quite a bit, but since the can be used to divide clocks or perform LFO duties, I don't think it ends up being overkill.
Wow, add oscillator to that list. I'm sitting here with it on fast cycle and giving it an oscillator's square wave to the gate and sending it's out to a vca, and there it is. Messing around with the envelope shape is resulting in all kinds of insanity while I look at it on a scope.
Holy shit.
revmutt
Knutty For Knobs
Post by revmutt » Sat Mar 13, 2010 11:12 am
this :nana:
sandy
Thanks sandy.
Tommy DOG
grantrichter
Lord of all Wogglebugs
Envelator audio uses
Post by grantrichter » Sun Mar 14, 2010 2:29 am
Holy shit.
The minimum time for both attack and decay is 1 millisecond. This produces a 2 millisecond (~500Hz) waveform. So the Envelator and be used for waveshaping if the frequency is below C above middle C. The Gate Input is a comparator with a threshold of ~2 volts so any oscillator waveform with an amplitude of +/- 5 volts can be used to gate it.
:cthulhu:
harolddonnelly
Post by harolddonnelly » Tue Mar 15, 2011 2:16 am
grantrichter wrote: voltage inverter, pre-amp, external balanced modulator, 2 channel mixer, headphone amp, 2 inch spring reverb (horror) and final volume control.
None of those is significant to the purpose, so I left them out. No deception was intended. The instrument shown is Serial No. 0, that is the original prototype which I received in pieces and had to reverse engineer in order to restore. So I got quite intimate with it. And I can A/B patches with the new modules and the 208.
I really love the ideas of these all inclusive systems
what would you guys suggest to finish off the final little piece that were left off?
Really enjoy the Malekko Spring Chicken I have great great reverb unit!
futureworlder
taking tiger mountain
Post by futureworlder » Thu Mar 17, 2011 11:44 am
Analogue Solutions HP-01 headphone amp will do 3-in mixer, preamp, final volume control and headphone amp in 6hp, Malekko's own OUTPUT will do 2-in mixer, preamp, headphone amp and final volume in just 4hp. Mr Malekko's design also outputs nicely in stereo with great imaging of panning and other spacial applications. i can't rightly recall if the HP-01 will do stereo out.
the only thing you don't get with either of these is separate volume controls for output and headphones, but i'd bet the reason for this is that most people won't be listening to the system (monitoring) on headphones at one level while the main out is at another.
i've A/B'ed both side by side in my mini-Wialekko system and found them both to be great, so i could go either way. inevitably i chose to keep the OUTPUT module mostly for space constraints, but i've got plans to incorporate the HP-01 into a DIY Buchla Easel clone as it just sounds too good not to.
opsysbug wrote:Please tell me they like each other so I can go try to scramble up yet another 3K of my retirement funds to waste on blinking leds and motorcycle sounds.
Entrainer
Post by Entrainer » Mon Sep 24, 2012 8:55 am
I'm revisiting this chart as I'm hopeful the new production facility and
prototype video equal = Anti-Envelope/Looper thing.
Plus there are some new modules such as the X-Mix, Fade, uVCA,
potential vapourware Cybernetics (as clearly stated in it's thread title) ...
Would a Cybernetics make more sense than a second Noise-Ring
Q: Those jacks on the bottom with no arrows? W-Bug?
2012-2013 may be the year I break out the 108HP row into a stand-alone
Malekko/Wiard desktop jam thing with headphone jack.
Planning potential configs to determine power + HP requirements for case.
5,159 custom drum samples for electronic music
made from 4 modular systems, drum modules, and some nice analog outboard processing
202 Instruments for Ableton Live/Push (128s), NI Kontakt, and Logic EXS24
41 Kits for NI Maschine, FXPansion Geist, Ableton Drum Racks, and Octatrack Sample Chains
http://www.drivenmachinedrums.com
Peake
Post by Peake » Sat Sep 29, 2012 12:07 am
Pic in first post: :hail:
thaneco
Post by thaneco » Sat Sep 29, 2012 8:59 am
Since I'm a fanatic buyer of Malekko modules, I would like to see a complete buchla system from Malekko. Otherwise Makenoise modules will be a better choice. Lets wait and see whats next! :sb: :wiard:
